Built LS1 Camaro PART OUT!!!!!
Well here is a start for a For Sale list.....If there's anything else you want that isn't listed just ask, b/c I probably have it.
Just send me your zip and I'll give you a shipping quote. Everything will be shipped from Huntington, WV. I will ship items out on Tuesdays and Fridays b/c I'm not going to run to UPS or the Post Office every day on my lunch break.
Any questions send a PM or email to the address below. I will try to respond as quickly as possible.
Thanks for looking!
Stephen
Paypal to stovetop357@yahoo.com
Motor (Approx. 4,000 miles on this setup) $2800
Car made 429rwhp/365rwtq through a M6 and a 9” w/ 4.10s
-01-02 LS1 Aluminum Block (Stock 3.898” Bore)
-01-02 LS1 Stock Steel Crankshaft (Stock 3.622” Stroke)
-01-02 LS1 Stock Rocker Arms (1.7:1)
-01-02 LS1 Stock Hydraulic Lifters
-Scat H-Beam Connecting Rods 6.125” w/ ARP 8740 Rod Bolts
-Mahle Pistons, 3.898” Bore, -4cc Dish, .927” Wrist Pin
-Ported LS6 Oil Pump
-Rollmaster Single-Roller Non-Adjustable Timing Set
-Clevite ‘P’ Connecting Rod Bearings
-Clevite ‘P’ Main Bearing Set
-Federal Mogul LS1 Camshaft Bearing Set
-Magic Stick v.3 .603/.609 237/242 113LSA
-Precision Race Components CNC LS6 Stage 1 Cylinder Heads
-PermaTorque Multi-Layer Steel Head Gasket (Left)
-PermaTorque Multi-Layer Steel Head Gasket (Right)
-Chromemoly Hardened Pushrods (7.400” LG)
-Complete Rebuild Gasket Kit
This motor has not been sprayed once since it has been put together.
Autometer 6” Tach with Shift Light $125 NEW $100
http://i140.photobucket.com/albums/r...7/P2240121.jpg
http://i140.photobucket.com/albums/r...7/P2240122.jpg
Autometer Mech. Fuel Pressure #4312 $44 NEW $30
http://i140.photobucket.com/albums/r...7/P2240124.jpg
http://i140.photobucket.com/albums/r...7/P2240125.jpg
Autometer Mech. Nitrous Pressure #4328 $84 NEW $50
Autometer Elec. Air/Fuel Ratio $30
98 LS1 Charcoal Colored Leather seats $500
(Front and Back)
http://i140.photobucket.com/albums/r...7/PC290084.jpg
http://i140.photobucket.com/albums/r...7/PC290085.jpg
http://i140.photobucket.com/albums/r...7/PC290087.jpg
http://i140.photobucket.com/albums/r...7/PC290088.jpg
http://i140.photobucket.com/albums/r...7/PC290089.jpg
3” True Duals under the axle $250
http://i140.photobucket.com/albums/r...7/PC290073.jpg
http://i140.photobucket.com/albums/r...7/PC290076.jpg
http://i140.photobucket.com/albums/r...7/DSC00430.jpg
LS1 stock air lid $10
http://i140.photobucket.com/albums/r...7/P2240112.jpg
http://i140.photobucket.com/albums/r...7/P2240113.jpg
4L60E Linkage $15
http://i140.photobucket.com/albums/r...7/P2240114.jpg
http://i140.photobucket.com/albums/r...7/P2240115.jpg
http://i140.photobucket.com/albums/r...7/P2240116.jpg
2 Centerline Center Caps $5
http://i140.photobucket.com/albums/r...7/P2240119.jpg
http://i140.photobucket.com/albums/r...7/P2240120.jpg
Stock Front Turn Signals $20
http://i140.photobucket.com/albums/r...7/P2240127.jpg
http://i140.photobucket.com/albums/r...7/P2240129.jpg
99 Camaro Driver & Pass Air Bags and Sensor $100
http://i140.photobucket.com/albums/r...7/P2240132.jpg
http://i140.photobucket.com/albums/r...7/P2240133.jpg
http://i140.photobucket.com/albums/r...7/P2240134.jpg
http://i140.photobucket.com/albums/r...7/P2240135.jpg
DG Motorsports Poly Urethane Body Kit $400 New $175
3rd pic shows a “hot spot” with my old exhaust
It should be able to be heated up and fixed.
First pic is what they looked like on my car.
http://i140.photobucket.com/albums/r...7/DSC00389.jpg
http://i140.photobucket.com/albums/r...7/P2240150.jpg
http://i140.photobucket.com/albums/r...7/P2240151.jpg
http://i140.photobucket.com/albums/r...7/P2240152.jpg
Thanks for looking!
Stephen
(Front and Back)
4L60E Linkage $15
I don't have any pics right now, they're still in the car. I can tell you that they do have some oil stains in between the primaries I couldn't get to. When the stock motor was in it I broke a piston and the pressure shot my dip stick out of the tube and some oil got on the headers, I got the majority of it off with a mothers powerball, but I couldn't get it all. I'll try to get some pics asap. They are the emission style headers, but 2 of the emission tubes where cut off and plates were welded on the holes.
I'm looking to purchase any stock GM LT1/LS1/LS2/LS6/LS7 catalytic converters.
Internals must be intact. Must not be gutted, hollowed out, or broken.
I pay well! $145 Paypal per set of 2 shipped or $70 for 1 shipped.
$20 each for pre-cats and $30 each for LS7 cats.
Please be sure to include your payment information in the box along with your LS1tech User Name.
Payment will be either by Paypal or check on the same day the converters arrive.
Please mail them to:
Hughes Burrow
1399 Tuscany Way
Germantown, TN 38138.
Thanks!
I don't need any extra pipe. Just need the converters themselves. You can cut them right after the welds to save on shipping costs.
A set of 2 converters cut from any excess pipe will fit into a USPS flat-rate box and will only cost you $8.95 shipped from anywhere in the U.S. directly to me. Flat-rate boxes are available to you at no cost at your nearest post-office.
Please email me at Muddinking@aol.com because I can't check the site as often as email.
I do buy other factory cats also. I can usually give you a price for them if I see a picture of them.
I am always looking to buy them so please don't hesitate to send what you have to me.
Hughes Burrow
1399 Tuscany Way
Thanks!
I pay $145 per pair or $70 each for factory LS1 LT1 LS2 LS6 GTO GM cats.
I pay by check or paypal, your choice.
Send your payment information with your cats, when you send them.
I pay within 24 hrs of the same day that I receive your cats.
Send cats to:
Dave McElrath
2942 Crosby Ave
Pittsburgh , PA 15216
No gutted or internally broken cats. Broken studs, bad flanges a-ok.
You can cut them out of the piping if you want.
The more you cut, the cheaper it is to ship. I just need the cats.
Fedx ground is cheapest.
Or , if you cut away all the piping , they will fit into a USPS ‘flat-rate” box &
Cost you only $8.95 from anywhere to me. Free “flat-rate” boxes at your post-office.
Check out my Trader Ratings at the top of the LS1Tech.com page.
I'm #3 on the list with 212 trades & a 100% rating...
You can also send me all other factory cats, & I will pay you top dollar, for your cats... I can only price non LS1 cats when received, as there are 1,000s of different factory cats made.
Send cats to:
Dave McElrath
2942 Crosby Ave
