Weber Racing 1 Time Deals. Heads, Shortblocks, Rotating Assemblies
We just did inventory and have some stuff we want to push out of here. Some of this is owned by employees of the shop, some is stuff that was left and never picked up for years. Some are special order that cannot be returned.
1) 427 CI Forced Induction Balanced Rotating Assembly
K1 Tech 4.000 Stroke Crankshaft
K1 Tech H Beam Connecting Rods
Wiseco -25CC Pistons 4.125 bore (Coated dome and skirt)
Wiseco GFX Ring Pack
Tool Steel Wrist Pins
Calico Coated Main and Rod Bearings
A customer ordered this, than decided to upgrade after everything was coated and balanced.
$2000 Retail over $2500!
416 CI L92 Flat Top Pistons
New L92 Block
Eagle 4" Crankshaft
Eagle Connecting Rods
Wiseco -3 cc flat top pistons
Durabond Cam Bearings
Speed Pro Main and Rod Bearings
Built To Stage 2 Specs, Fully CNC Blueprinted block!
All parts are here just needs to be assembled
$3899 Retails at $5495
Stage II 383 LS6
New LS6 Block
Wiseco Pistons - 8cc
K1 Tech Connecting Rods
Eagle Crankshaft 4"
Speed Pro Bearings
Fully CNC blueprinted block
$3499 Retails $4375
2 sets of 98 853 casting heads, bare $40 each
1 set of 1999 LS1 853 casting heads. Milled .060 $30
Many stock valves and springs from 98-99 heads
Valves $4 each Springs $2 each
Im sure there will be more to add later
New L92 Block
Eagle 4" Crankshaft
Stage II 383 LS6
New LS6 Block
Eagle Crankshaft 4"
Speed Pro Bearings
$3499 Retails $4375
From: sneaking in your back door as you leave!/cartersville ga
it says the 427 is for forced induction apps.
Maybe you might want to read a "little". The 427 is a rotating asembly, not a built block.
Im looking for something that is ready to go, and would work with my P1SC, and I dont think that a P1SC is near big enough for a 427.
oh yeah, they build motors so i am sure they have a block or two laying around.
