Vehicles For Sale - LSX Powered ONLY ONLY LSX POWERED VEHICLES - NO TRADES UNLESS YOUR VEHICLE IS LSX POWERED!!!!!!
2001 Trans Am - fully built Twin Turbo LS1
Old Aug 21, 2008 | 08:31 AM
SonofaBish's Avatar
Default 2001 Trans Am - fully built Twin Turbo LS1
Yes, I am putting my baby up for sale .... its a 2001 Pontiac Trans Am. This car is absolutely awesome. It has impressed/awe'd EVERY single person that has ever been in it I spent over a year and a half building/completing the twin turbo kit while still leaving this car 100% street legal. I'm asking 20,500 OBO, which means I'm not getting back even close to half of what I have put into it - I thought I'd never sell, but I have other aspirations in life now.
The car itself has just over 74,000 miles on it - but the engine, turbo kit, clutch, rear end, etc all have less than 1,200 miles on them. The black leather interior is in incredible condition and the black exterior is amazing as well.
The car is meticulously maintained. Only the very top end oils and lubricants have been used in this car! When not in use, it sits in my garage under a cover, and gets waxed quite often to keep its shine.
The car made 698hp and 706tq to the rear wheels on 93 octane PUMP GAS. All that while on an extremely conservative 13.5psi, 11.0:1 A/F ratio, 12* of WOT timing, spraying 50/50 meth/water. The engine is a fully forged LS1 motor (348ci) that was built to handle far more horsepower than the car is currently pumping out. I had it tuned soo conservative because I didn't want to take the chance of a misfortunate bad tank of gas or something!
Its hard to describe in words just how awesome this car is - you have to see/feel it to believe it. It looks absolutely amazing, and runs TOP NOTCH! Traction? guys with 200rwhp less complain about not being able to get traction, but this car puts all 700rwhp to the ground - its quite a feeling. I have no traction issues at all, as long as the temperature is above 60* outside - not even in first gear.
Below is a list of the mods done to the car. There may be some missing, but I think this pretty well details just how well built this car was and how no expense was spared to make this a reliable, and 100% streetable monster!! If you want to rule the streets, this is your car! If you have ANY questions whatsoever, please feel free to ask. I have lots of pictures and also have added a couple videos. Serious inquiries will include a response with my phone number to discuss anything you may want to know.
The car at idle - sounds extremely healthy and the cam gives a nice lope!
http://video.google.com/videoplay?do...09951877&hl=en
A few small revs - the turbos make themselves well known, especially driving down the road
http://video.google.com/videoplay?do...41263549&hl=en
Modifications
Engine:
• Stock aluminum block LS1 (5.7L), bored .010 over (348 ci)
• Polished crank and fully balanced rotating assembly
• -16cc Mahle forged pistons w/ file-to-fit rings (filed for blown/turbo application)
• Eagle 4340 forged H-beam connecting rods w/ ARP L19 bolts
• Clevite bearings throughout
• Ported and polished 5.3 heads (heads/valves have 3000 miles)
• ARP head studs
• GM MLS head gaskets
• Comp Cams 220/224 .564/.568 115 lsa, custom turbo grind cam – custom grind for mid-range torque
• LS2 timing chain
• LS6 ported oil pump
• LS6 intake manifold
• Patriot Performance Gold dual springs, with titanium locks and retainers
• LS7 lifters
• NGK BP7EFS spark plugs
• Full A/C, heater, etc.
Turbo Kit:
• 58mm Precision turbos (2) – T4
• Custom built, thick walled stainless steel headers
• 3" Stainless steel downpipes, connecting into 4" stainless exhaust, then exiting to dual/dual 3" stainless tips
• Stainless steel charge piping
• Very large 2in – 1out air-to-air intercooler (polished)
• 38mm Tial wastegates (2)
• 50mm Tial Blow-off valve
• Slowboy Racing manual boost controller
Fuel System:
• Twin 255lb Walbro fuel pumps (2)
• Custom pressed steel-braided fuel lines
• Aeromotive fuel pressure regulator
• Aeromotive fuel rails
• Seimens/Motron 60# high-impedance fuel injectors (flow-matched)
• Mallory fuel gauge isolator
• Snow Performance Boost Cooler methanol injection kit
Supporting Mods:
• T56 6-speed manual transmission
• Spec Stage 3+ clutch
• Custom aluminum driveshaft
• Moser 12-bolt rear end
• Detroit True-trac differential w/ 3.08 gear ratio
• Mickey Thompson ET Street Radials – 255/50R16
• A-pillar 3 gauge pod – wideband o2 (a/f), fuel (psi) and boost/vacuum (psi/hg)
• Custom short-throw shifter
• Custom "in-floor" subframe connectors (2"x4")
• BMR tubular K-member
• Polyurethane motor mounts
• US Exotics Superhawk fiberglass hood (1 of 500 made)
• Custom 3-bar speed density tune by Nate @ TPG Tuning
**This car made 697.56hp and 706.16ft lbs of torque at the rear wheels on only 13.5 psi of boost. This was also at an air/fuel ratio of 11.0:1 and 12* of WOT timing.
Asking 22,900 OBO. Trades will be considered, but trade + cash must be of equivalent value to what I'm willing to accept. I have lots of pics, but my laptop crashed 2 days ago and I don't have access to Photobucket here at work. So here are a few that I have on fquick until I can get access to my other pictures.
http://www.fquick.com/sonofabish
Old Aug 21, 2008 | 09:13 AM
white01ss's Avatar
TTT for a badass car. Any track times?
BTW, the fquick link is not working for me.
Old Aug 21, 2008 | 09:33 AM
SonofaBish's Avatar
Thanks for the props!
No, i do not have any track times. The nasty weather lasted way too long this spring in PA, and by the time the weather was nice, it was time for me to start studying 3 hours a night after work, in attempt to pass my professional exams.... That finished up in late May, and Test&Tunes are 1.5 hours from me on Wed. nights. It kills me, but i just never seem to find the time to get out there.
Thank you for the warning about the fquick page! I will try to fix it.
edit: url fixed in original post
Old Aug 21, 2008 | 09:45 AM
SonofaBish's Avatar
A few things i forgot to mention:
CR = 9.0:1
The fuel system as it sits is good for about 850rwhp. When the car was on the dyno, the tuner and I were interested in what the car would put down with 16psi and we ran out of injector around 4000rpms with the car in the 820rwtq range. He said the fuel pumps/rails/lines were fine, but the injectors were maxed. Larger injectors and it'll obviously support quite a bit more power.
Old Aug 22, 2008 | 05:39 AM
SonofaBish's Avatar
TTT....
I will be out of town for the weekend. If you are interested in the car, please PM me and I will return your PM when i get back Sunday night. I am sorry for the inconvenience, but I do not feel comfy posting my phone # on the whole inter-wide-web
Thanks!
Old Aug 22, 2008 | 06:09 PM
CH Conceptz's Avatar
Sick Car...
The vid links are not working.
I had 98 WS6 Heads and cam. Sold it over a year ago. Looking into getting a High HP TQ monster. for a second car. This is perfect.. I am orignally from York, PA. my hometown. Can you get some more pictures up of interior and things. and vids if possible. I am thinking this over... real hard..
thank you,
cory
Formly OneBadBird on the forums.
Old Aug 22, 2008 | 08:43 PM
Breathtaker's Avatar
Awesome ride, GLWS!
Old Aug 24, 2008 | 03:38 PM
SonofaBish's Avatar
Originally Posted by CH Conceptz
Sick Car...
thank you,
cory
Sure thing. I will get them up a.s.a.p. I just got back in town about 10 mins ago, so I have to get things unpacked, etc and I will throw everything up. I'm not sure why the links to the vids don't work, b/c other sites seem to be having success with them. I'll look into it!!
Thanks alot!
Old Aug 24, 2008 | 03:46 PM
SonofaBish's Avatar
Video Links in original post fixed!!!!
After i get all my stuff unpacked from my trip, i'll throw up some pics...
Old Aug 24, 2008 | 06:35 PM
SonofaBish's Avatar
Engine sitting in the cradle, with the turbos attached
Picture of the charge piping going into the intercooler while it was fully welded together.
I also have some pics on www.fquick.com/sonofabish
Once again, i really apologize for the lack of pics.... Like i said, my laptop crashed, and I had a very limited number of pics hosted on websites... If you have anything you want to see, I can take a pic
Old Aug 24, 2008 | 06:43 PM
SonofaBish's Avatar
and here's a pic from before i put the Firehawk hood on it... just to give you an idea of what the front end looks like with the intercooler
with Firehawk hood
Old Aug 25, 2008 | 09:26 PM
SonofaBish's Avatar
Ttt....
Old Aug 25, 2008 | 09:32 PM
1badWS6's Avatar
bump for a bad *** ride
Old Aug 25, 2008 | 11:16 PM
stryder's Avatar
im in love with your car man wish i was closer this is just what i have been wanting lol
Old Aug 25, 2008 | 11:27 PM
badpanda's Avatar
bump for a fellow pittsburgh T/A
Old Aug 25, 2008 | 11:37 PM
SCott5's Avatar
I personally seen and heard this car and i must say this is the baddest car i have ever witnessed. Bump for an awesome car and good guy
Old Aug 26, 2008 | 05:56 AM
SonofaBish's Avatar
I'm willing to accomodate in any way i can....
Thanks guys!
Old Aug 26, 2008 | 07:29 AM
foxrus14's Avatar
Bump for ya Bish. After all that work, I can't believe you are selling. Bad *** ride. Good Luck
Old Aug 26, 2008 | 04:50 PM
RDY2RUN's Avatar
Talking Ta
I bet it gets great mileage with that 3.08 gear. But seriously, one bad *** TA. If you still have it after I sell my TA I would be interested.
Old Aug 26, 2008 | 09:15 PM
SonofaBish's Avatar
haha, actually yeah, it gets 30-32mpg on highway trips... but that's obviously going to be easily negated by a few WOT runs
