KARS III Whine...
I say blower kit because the rear end whines constantly now, louder than before. I assume its driveline vibration thats being picked up through the solid mounts, but man... its kinda annoying.
On the up shot, wheel hop and traction issues arent an issue.
Has anyone had a similar problem?
I never installed mine, the only other car I drive with the Kars III howled like a bitch. Deleted cats and a 408 solved it.
Those interested in purchasing it from me, stay tuned, I have a total of about 7 miles on it now.
EDIT:
The fix for the whining is painfully simple. I was looking at it today and realized that all I needed to do was:
Remove the pinion carrier bolts so that the rear bracket was no longer attached to the traction bars.
Then I hit the local Kragen and buy a set of rubber bolt on style bump stops and shave them down to where they fit in the pinion support area.
Now I have a daily driveable traction kit, with a pinion brace when I want to go to the track, just have to swap the rubber bushings for the two pinion bolts that attach the bracket.
Simple fix, howling is gone, and the V has no wheel hop issues.
