Any stick guys with a 12 bolt in here?
Thanks, I put a spool in it never thinking I would blow the ring and pinion apart. That gear set had about 20 hard nos launches and pop. The thing that sucks is it broke at pinks all out. Friday car ran o.k. went 10.5 at 130. I was going to up my shot but not sure how much I would pick up with another 50hp so I left it alone. Sat. on the first pass boom my day was over.Now I have to switch to a set of pro gears which are track only gears unless I feel like throwing money away every 20 passes. I might just start looking for a back up rear
http://photosbyjim.smugmug.com/galle...011_ApYpD-L-LB
http://photosbyjim.smugmug.com/galle...587_2tnb6-L-LB
http://photosbyjim.smugmug.com/galle...484_pbtXJ-L-LB
there's more shots on Englishtowns web site if you click on photo shop
What tires are you on?
This thread sounds so fimilar to what happened to me. After breaking 4-5 10bolts trying to get into the 11's I upgraded to the 12bolt. It worked fine until I started reaching the 10's. First time I broke the posi unit, second time twisted an axle (33 spline), third time broke r&p. So I had enough of it, pulled it, fixed it and sold it. Then bought a 9inch and have yet to hurt it. All of that breakage was pretty much at full weight thought. Now i'm much lighter but also much faster. Hope this helps.
