SBC into fox body mustang motor mounts!!!!!!!
I am building a fox body mustang, dedicating it to a friend of mine who recently passed away at the age of 21 due to some complications from a car wreck that wasn't his fault. He was a big time mustang fan. I want to build a fox body mustang ( haven't decided on a year yet, need help with that also) and put a small block chevy with either a th350 or a th400 tranny in it. I need some major help. I was wondering if there are any aftermarket swap kits or if i'm gonna have to fabricate them. All input is highly appreciated. This build means a lot to me and many people and I just need some advice before I start. Thank you all.
Thanks for the help. I've never used a motor plate before. How difficult is it to do. I found some pretty reasonable, but they give me the option of center or offset crank? Which one should I use?
Im using the AJE Kmember with my Mustang 383 swap.
K-member:
http://www.jegs.com/i/Anthony+Jones/...-30UM/10002/-1
Mounts:
http://www.jegs.com/i/Anthony+Jones/040/MU-30/10002/-1
K-member:
Mounts:
im doing tthat same build a im gonna use the aje kmember with the chevy mounts wich aje also sells it reduces alot of weight an also makes it less of a hassle an gives you alot more room than using the stock one but i also recommend getting the aje crossmember with it for the tranny an if i remember right you can use the stock shocks an lower control arms with it but i would get coil overs with new lower control arms anyways
