800 HP SB-2 how fast
I have a 2000 camaro.... weighs in at 3230 with driver
Just installed 800 hp 368 sb-2 motor
Bowtie block with roller cam bearings 4.152 bore
6.050 titanium GRP rods
Custom Cola crank 3.400
Custom JE pistions14.5 to one
Custom built solid roller cam shaft 814/768
Jessel rocker system,
SB-2 Nascar heads,Titanium valves flows 402
1.85,1.80 rocker arms
Carls....Competition trans , custom converter
10.5 tire 9in 410 rear 35 spline axles
Made 798 hp at 7800 rpms,and 567 TQRQ at 6600 rpms
Just want to know what I'm looking at for ET's
Thanks Tony
Thanks Tony
Thanks Tony
Thanks Tony
keep us posted
Thanks Tony
Thanks Tony
http://www.race-cars.net/calculators/et_calculator.html
Also depends on the amount of error built into this calculator. Either way your car will be flyin!
In-Zane Moderator
It will depend on the rest of the setup. That bore and stroke is for higher end screaming for rolling 200 MPH on a roundy pound, not to mention the torque tells it all. Not a dead stop quarter pounder. But it will run depending on where you stall it and what hears. It hs no choice but to move.
