brodix ported titaniun valved sbc heads/cam
holley hp 1050 dominator main body freshly machined- 200 obo
mallory comp 5 inch tach with memory recall- 125 obo
true double roller billet timing chain/ gears for sbc - 100 obo
Brodix SS aluminum 23 degree sbc heads completely worked, 208 intake 160 exhuast titanium valves with harneded steel tips, $1400+ in port work blow blended smoothed runners, o ringed, tapped for extra cooling bungs, pushrod openings clearanced, 7/16 screw in studs with guideplates, 1.550 k motion roller springs, titanium retainers, 10 degree locks, milled .30, oil passages opened up, everything possible done to these heads has been done. the valves alone cost 1200 and the springs are new.
also for the heads is the matching solid roller cam custom grind by dynamic cams. 650 lift. have full specs to buyer.
have the comp cams lightened solid roller lifters for the cam too.
heads/cam went 5.70's 1/8 mile in 2600lb door car 406 motor
