This is not a classifieds forum. Post ALL sales in here.
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
If anyone needs help getting started on a BBC conversion, I have a set of 2 1/4" primary Jet hot coated race headers with built on Dynomax collector mufflers for sale. Were on Big Chief and Brodix BB2 heads. Went 7.70's @ over 170 mph!! Came out of a '70 Nova, but they should fit in a 4th gen. I think? Just thought I would throw that out there. ASKING $650 or trade for Ls1 motor stuff.
This is stuff that i had before i got my LS1.
Weined 142 roots type supercharger with holley 980
World Products S/R Torquers
Aluminum L98 machined to 57cc cambers with 2'' stainless steel manley raceflow intake valves, 1.6'' stainless steel manley raceflow exhaust valves, 10' locks and retainters, comp cam double valve springs
1.6 intake roller rockers and 1.5 exhaust roller rockers
Comp hydrolic roller lifters
Erson cam 226/234 .544/.510 with these rockers
TRW .040 forged pistons
GM "pinky" rods
4 bolt 350 that has been bored .040
Dayna 60 4.10 rear setup for a 3rd gen with disc breaks
2 t5's
2 turbo 350's
I just wanna get this stuff out of my garage so make me an offer
I have some pics if needed
GM "pinky" rods
2 t5's
2 turbo 350's
Misc. Motor Parts, Monocoque rims, suspension. WILL TRADE FOR LS1 OR LS1 PARTS, TURBO PARTS!
-509 BBC:MERLIN 2 BLOCK 9.8 DECK, 4.500 BORE W/BILLET SPLAYED CAPS,(NEW), $1900
-DART 360 HEADS FULLY PORTED BY SCOTT SHAFFIROF, MACHINED FOR JESEL SHAFT ROCKERS (NOT INCLUDED) W/NEW ARP STUDS, $2500
-CALLIES STEALTH CRANK STD/STD, $900
-GRODEN BILLET ALUM. RODS 6.385(NEW), MAKE OFFER
-10 ROSS CUSTOM NITROUS PISTONS TOOL STEEL TAPERED PINS AND BUTTONS (NEW), MAKE OFFER
-STEFS ALUMINUM OIL PAN, $200
-OIL PREHEATER (NEW), MAKE OFFER
-ATI 7" BALANCER AND TAVIA POINTER (NEW), $220
-JEFF JOHNSON FABRICATED VALVE COVERS WITH EARLS REUSABLE GASKETS (NEW), $350
-PRO SYSTEMS NITROUS PRO IV 1250 DOMINATOR (FOR STREET USE), MAKE OFFER
-MOROSO VACUUM PUMP (NEW), $ 350
-MOROSO BILLET 0IL PUMP, $220
-CVR PROTORQUE 3 HP. MINI STARTER (NEW), $230
-JESEL BELT DRIVE 2 NEW BELTS INCLUDED (NEW PARTS), $600
-WILSON SUPER VICTOR CNC, MAKE OFFER
-Jesel Dogbone lifters p/n LFD-46501, 905 Body, .820 Roller centered cup with retainers p/n KDR-56112 for big block Chevy. New in box, never installed $2400 new, make offer.
-Big block aluminum motor plate $60
-Product Engineering fuel system (new);pump/filter combo p/n PE4450, Dual relay wiring harness, 4 port regulator, Double regulator bypass, many Hi-Flor fittings and more $1,100 new, selling for $850
-Holley ICT (individual Cylinder Timing) ignition p/n 800-400 with coil 820-100, Billet distributor p/n 890-1010 and Hall effect crank tirgger for big block and 9mm annihlilator plug wires, all new $1,000
-Monocoque pro star rims w/ Mickey's 26x4.5 front, 15x11 6.5" B.S. 28-10.5W rear with tubes and are all screwed, all new $1,700
-Alston pro ladder bars, brand new, make offer
-Strange Engineering heavy front disk brakes with spindles (one season old) make offer
-Nitrous Express Gemini twin pro power for dominator, 100-500HP, comes with master flow check, brand new, $675
-9" Freddy Brown nitrous converter, just freshened $700
-Moroso Camaro/Nova big block front drag springs $65
-Chassis Engineering coil overs with springs $300
-Cheetah shifter with command center (new) $300
-12 bolt rear: .250 Wall chromoly tubes fully welded, 33 spline strange axles, spool, c-clip eliminators, 3.73 OR 4.10 gear, TA Cover, 1350 pinion yoke, Strange Engineering disk brakes, make offer
-Flowmaster 4" one chamber exhaust with turndowns, $100
-Powermaster XS 150 alternator #8158 (new), $325
-Custom headers (Went 7.70’S @ over 170 mph)Camaro/Nova big block 2-1/4" with Dynomax collector mufflers, ceramic coated, $600
11 & 7 Second Clubs
1. Keith Sykes Powerglide racing transmission, for high HP big block Chevy, with 1.76 super gear set, steel clutch hub, trans brake, hardened input shaft, deep aluminum pan, trans shield, flex plate shield; 40 runs, freshened after 30 runs: $1400.
2. Precision Industries, 9.5" high stall torque converters (2), 20 runs ea.
ea.; free reflash available from Precision. Will sell converters separately for $500 ea, plus shipping.
bbc ps pump w/brackets 75.00
bbc stock ex manifolds 50.00
bbc pullys 15.00 each
alternator and brackets 35.00
hei vac advance dist 75.00
msd 6al with rev limiter 130.00
e-mail me at JBANKS322@aol.com all prices plus shipping
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
[QUOTE=nitrorocket]Misc. Motor Parts, Monocoque rims, suspension. WILL TRADE FOR LS1 OR LS1 PARTS, TURBO PARTS!
Do you have any need for a 72 SBC 385 Stroker Kit (New)
or a
1973 Corvette LS4 454BBC Motor?
or a
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
2 t5's
2 t5's
I'm interested in the above items. If you still have them would you mind sending picts. and prefered prices?
Thanks Much!
I've got my 498 up for sale
5140 forged crank, 4340 h-beam rods, srp forged pistons, lunati valvetrain, hyd roller cam, ported 049 casting heads( bronze valve guides, 2.19/1.88), ported strip dominator intake, Proform 950 carb. $3500 for the whole set up.
Let me know if interested.
Later
Rassan
Later
Rassan
i've got a 350 2-bolt block that is .30 over and notched for 3.750 stroker crank.. block is in really good condition and the cylinders look like new. also have a GM Performance Parts 3.750 stroker crank that is still bolted in the block..
asking $300 and prefer local sale only or i can meet somewhere within 1-2 hours..
email is matt_shabani@yahoo.com Thanks!
BMR tubular (powdercoat black) k-member w/out motor mounts for a BBC/SBC swap in a 4th gen fbody wanting to use motorplates...
it has NEVER been used...this is BRAND NEW!!!!!!!!
I am asking $400 and you pick up
it is in College Station, Texas as are all the parts I am listing here...
PART# KM005-1 "Tubular K-member for traditional small block Chevrolet and Bigblock Chevrolet. For use with Pinto style manual rack."
I also have a set of bare aluminum heads with substantial but not complete portwork done...they will need machine work as all bare heads do when ordered from manuf. .....these are also brand new and never been used
Dart Pro 1 345cc Big Block Aluminum Heads...$1500 + shipping
Corbeau race seats (2)(black)(USED but in great shape)...weight ~16lbs a piece...they are the Forza's and I have the seat brackets to install them in a 4th gen fbody...I will throw in a pair of 5 point harness free(expired)...asking $500 OBO or a straight up trade for a leather 1998+ T/A interior front/back with lumbar/power wiring(runs under carpet)...if wanting to trade I am willing to negotiate, PM/email me your offers
hot tanked 454 GM 2 bolt block...has been run prior to the hot tank...$275 OBO
forged GM crank 4.25 stroke, stock journals(BBC)...never run
aluminum rods 6.385 length, manley super 70's(BBC) ...brand new
brand new SFI flex plates(2)....
Th400 built by Jimmy Arabie in Baytown, Texas(lokar dip stick, blue clutch packs, transbreak, reverse pattern race tranny...the works!) Just refreshed with no passes since refresh...prior to refresh it was run in a 72 Camaro making 750-800hp with no probs...I will include a 3-3.5 mild steel DS that came from a 1972 Camaro with a Ford 9" that has been used to run 1.30 60ft's with no probs!
PM me if interested or email me at prietojr@hotmail.com
454 c.i. big block for sale. Came out of a 1975 chevy truck, not sure exactly what model. Only has around 50k miles on the block itself. Two-bolt main, and it is a Mark IV. Comes with stock pistons and rods. Asking for 500$ obo. PM me or email me at bud794@hotmail.com. Also have pics of the block if you want them.
Originally Posted by Bud794
454 c.i. big block for sale. Came out of a 1975 chevy truck, not sure exactly what model. Only has around 50k miles on the block itself. Two-bolt main, and it is a Mark IV. Asking for 500$ obo. PM me or email me at bud794@hotmail.com. Also have pics of the block if you want them.
Ohhh, I was, but the 79 camaro I was going to put the 454 in got sold for a decent price (about 1800$ for a pair of red 79 z28's in rusted condition). It got a little too expensive owning and maintaining all 3 cars
. I also don't have time or the money to work on them, because I work full time and go to school. I also plan to move in about 4 to 6 months into the country. The block still has the stock crank in it along with the stock cam.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I think it is a cast crank. Is there any other ways to tell whether it's a cast iron crank or forged steel other than tapping it lightly with something hard? But I think it's a cast iron crank...
Update:
Okay, I checked the crank wheel for parting lines, and found a thin parting line which denotes a cast iron crank, whereas a thick parting line indicates a forged steel crank according to a cartek book on BBC's.
Update:
I have some stuff for sale..
I have a pair of vortec heads 060 castings, Came off my old engine with 80k miles. I have a set of conditioned valves and brand new valve seals that i will give away with the heads. The heads are complete the way they sit, the seals and valves will be thrown in on top of that. 250 + shipping is what im asking for that here are some pics
I also have a pair of springs and retainers, im not sure the brand. They look like crane springs and retainers. Anyways i was told these should support 550 lift without seat/guide modifications. 100 bucks + shipping for those
I also have a brand new water pump, not sure what year truck its for but it has a v-belt pulley on it also.. 30 + shipping?
Thats all i can think of now, ill add more if i can think. I need to get rid of this stuff
