Big torque motor for my bus.
I just bought a 1993 GMC School bus and it could use a bit more power, its got a TBI 350 and is lacking in the power department. So I need a build plan for a small block with massive low and midrange. And getting a bigblock isnt an option.
Thanks for the help and if you guys want to see pictures I'll take some and post them up.
ok, i vote to have FattyMcTrickle temporarily banned, if not removed from this board for asking a quetion in reguards to a "bus"! j/k.
well, unless you're willing to drop "massive" amounts of cash on this build, you're not going to get "massive" anything unless your description of massive torque is different from mine. i'd just leave this thing well enough alone, or rebuild as stock if it's in need of an overhaul. it's a bus! you'll never get much of a power to weight ratio without dropping a ton of money, and gutting the bus down to it's frame. the money would probably be better used elsewhere i'm guessing, like in another vehicle with a few thousand less pounds. sorry for the answer, but i'm not sure anyone else was planning on chiming in with anything much different and i don't know what you're expecting to do or get out of this thing. fire away if you need to.
ps, I know you said "no" to a big block but www.sdpc2000.com has a 502 big block for $5200, puts out 512 ft. lbs @ 2850, part # 88890534 or convert to a diesel???
Figure the TBI 350 in a bus puts out 150hp/250ft lbs stock. I would assume he'd be happy with 400hp/450-500 ft lbs. You can do that extremely easy, and cheap. Just build or buy a 383 and have fun with your new found torque and hp. A very mild 383 will easily put 400/450ft lbs.
I'd be perfectly happy with something about 350-450 ft/lbs. but the RPM at which power is made is important, I want torque from idle to like 3k. I'm not looking to do a burnout or race but I wouldn't mind not having to aviod large hills. I was thinking I could go carb'd for simplicity and get a cheap 400 with a rv cam (I hate to say that) but I don't know quite what to look for.
And just for some backround I'm 17 and me and another friend threw some money in to use it as a mobile hang out spot. I work as a (intern) Tech at a local dealership so there is nothing I can't do myself and the engine is actually very easy to work on.
