lunati voodoo cams
lunati voodoo cams
has anybody ever use the lunati voodoo 268 duration cam .489-.504 lift. If so how did you like and did it have a nice lope to it im wanting to put it in a 350 with flat top pistons 1.94-1.50 heads if you have a sound clip i would very much appriciate it thanks in advanced.
i have ur same engine combo
i use the 268 vodoo in a over bored sbc, here is the sound clip u wanted..its a truly awsome lopy cam..but u must install it 4 degrees advance to get decent bottom end..the redline should be about 6000 rpm at 4 degress advance..36 degrees timing advance at 3000 rpm with the vacume advance disconected...
http://videos.streetfire.net/video/F...LER_146567.htm
