Oil from intake bolts??
Ok so I finally got the car running but it still needs a little tuning. The other day the car got a little warm on me (210+/-) and the intake started to leak a little coolant from one of the blocked off water temp spots. so I figure its kinda hot so all that pressure is making the intake move around and is letting some oil seep through the bolt holes.
Any ideas?
Also, when the engine got warm it started to stumble and wanted to die when given gas to accelerate. It was running good before so im a little stumped.
Any ideas?
some silocone will work nice too..... just a lil dab at the end of the bolt before you install it! a good rule of thumb is to basicly put a lil dab on anything bolt that needs to stay put..... loctite is a good item to use too but i dont know how much it will help on oil leaking..... its seems like it could seep through a few places cause the silocone actually forms a nice even application and the loctite can sometimes not spread evenly...... both probly work just as good and i may be wrong
