Vortec 906 casting
the thing about the 906's is that some people say because of how the exhaust seat is manufactured/hardened it inhibits mid-lift flow on the 906's vs. the 062's
however there is a lot of conflicting information out there on these heads some say yes some say no
^^^Correct. I have 906's on my 383, this is the info I found when I was researching this a couple years ago:
The only difference between the 062's and SOME 906's is SOME 906 vortec have a pressed in hardened exhaust seat as oppoesed to a factory flame hardened exhaust seat. The pressed in seat just flows a bit less than the other heads seat. Simple bowl porting (blending) under (deeper) the seat will eliminate any real or perceived difference in flow by eliminating the machined metal "edge" left from the OEM manufacturing process.
I did a little hand blending and fixed them right up.
its not they are hardened. all valve seats have been hardened since the 70's.
SOME 906's have a single angle valve job on an Iconel valve seat which is EXTREMELY hard.
As for the Inconel material, they are harder than a standard induction hardening but are still preaty "soft" compaired to the material we use for the proper LPG conversion. Stellite valves and valve seats are much harder to machine on the valve jobs......
