Stainless Works "special request" S10 Header group buy!
#221
I wish. I have to pull the engine and trans to modify my crossmember notch since Im not happy with the new one I made for the new mounts. Its only about a 1/8" clearance from the bottom of my oilpan. Swapping out the a/c heater box for a heat only box while waiting on the CircleD tq converter to arrive on thursday then I can toss that in and reinstall the engine and trans, Run lines for the trans cooler remove the seats and carpet to install the gear shifter and shifter cable to the trans, remove the clutch pedal, throw down lizard skin insulation on the cab floor and reinstall the interior. Then its just reinstalling the engine harness and other various components redoing the front half of my exhaust to meet up with the new headers then hopefully itll be back up and running. By the middle of May is my goal to have it running
Those GTO seats look fantastic in there BTW.
-Jason
#230
These ended up at $890
They do include O2 sensor bungs
You can still get in on the group buy. SHOOT ME A PM!
The first 10 sets are shipping this week, then 10 the next week.
#231
Can you confirm that they will fit between the frame rails on a 1st Generation S10 Blazer?
#236
I'm test fitting these with BRP mounts. Got the driver side in yesterday. Had to trim the back side of the UCA just a bit (stock arms) just a bit, but other than that they fit great! I'll be tackling the passenger side in the next couple days and will post updates.
#237
EXCELLENT! Will be great to find out fit with other mounts!
#238
Got the other side in. Getting it in was a PITA, but mostly due to my JW Ultrabell on a TH400.. I had to loosen the body mounts and lift it up and do some floor clearancing to get them in place. But once they were in, I have good clearance on everything. In fact, they fit better than the BRPs did, even with the larger primaries. All in all, very happy with the final product. Thanks guys!
