Bc racing coilovers $995 shipped!!! @ iir's muscle division(Threads Merged)
IIR'S MUSCLE DIVISION IS YOUR OFFICIAL SOURCE FOR
We are the #1 Vendor in the nation for BC Racing coilovers!
BC Racing BR series Coilovers Free Shipping Anywhere in the USA!! Free Custom Spring Rates/Valving as well! Pm or email shawn@importimageracing.com for your special LS1 Tech price today!!!
FOR YOUR 04-06 GTO, 08-09 G8 AND 10-11 CAMARO
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment ***** for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
What do I get?
Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical Specs?
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
IIR'S MUSCLE DIVISION WILL MEET OR BEAT ANY COMPETITORS PRICE. WE WANT TO EARN YOUR BUSINESS AND KEEP IT!!
FREE SHIPPING ANYWHERE IN THE USA!!
Any questions or comments please let us know and we'd be glad to help you out. Don't see what you need? Let us know, we carry many different lines in stock daily to serve the LS community.
Need a deal? We can help with these products and more just let us know! We're here to service you LS1TECH Members!! http://www.iirmuscledivision.com
Torque Solution Engine Mounts 2010-11 Camaro! Special Price Here!
IIR'S MUSCLE DIVISION YOUR OFFICIAL SOURCE FOR
**BILLET ENGINE MOUNTS**
**MADE IN THE USA**
**LIFETIME WARRANTY**
FOR YOUR 2010-11 5TH GEN CAMARO
$295 MSRP PLUS SHIPPING?
NO!!
**IIR'S MUSCLE DIVISION IS OFFERING A LS1 TECH MEMBERS ONLY A SPECIAL PRICE W/ FREE SHIPPING IN THE USA**
MORE INFO?
MORE INFO?
All Torque Solution engine mounts are made with both quality and performance in mind. These mounts are a direct replacement for the OEM factory mounts. OEM mounts are made of sub-par material with rubber bushings that are infamous for deteriorating, cracking, and tearing over time. Heavy racing or spirited driving tends to speed up that process. Torque Solution has you have covered! Our mounts are made out of high grade 6061 billet aluminum material for weight savings and polyurethane bushings for long life and consistent performance. This combination allows the wasted energy to be transferred to the wheels where its needed for optimal performance.
WHAT TO EXPECT?
•Eliminates wheel hop / traction loss
•Improved 60fts / e.t's
•Made out of lightweight 6061-T6 billet aluminum
•1000HP+ and 7sec e.t. torture tested
•Black anodized
•85A durometer bushings
•LifeTime Warranty
•Made in USA
•Black anodized
•LifeTime Warranty
•Made in USA
WE WILL MEET OR BEAT ANY COMPETITORS PRICING. WE WANT TO EARN YOUR BUSINESS AND KEEP IT. LIKE WHAT YOU SEE FROM TORQUE SOLUTION? WE ALSO OFFER THEIR SHORT SHIFTER!!
Fuel Injectors!! DeatschWerks Super Sale & Free Shipping!!
IIR'S Muscle Division YOUR OFFICIAL SOURCE:
SPECIAL LIMITED TIME OFFER!!!!
WE ARE TAKING THIS DIRECT MANUFACTURE DISCOUNT AND GIVING IT RIGHT BACK TO THE PEOPLE OF LS1TECH!!
Options:
42lb/hr 15% OFF! SHIPPED FREE
50lb/hr 15% OFF! SHIPPED FREE
65lb/hr 15% OFF! SHIPPED FREE
UP TO 105 LB/HR!!
PM OR EMAIL shawn@importimageracing.com FOR YOUR SPECIAL LS1TECH PRICING TODAY!!! INCLUDE YOUR YEAR MAKE MODEL AND DESIRED INJECTOR SIZE!
All sizes feature the following:
- Flow rates and set balancing in-house by DeatschWerks
- Flow balanced to within 1-2% (flow report included)
- High Impedance coils to match OEM ECU
- 100% drop-in fitment (no connectors or adapters required)
- Excellent spray pattern and atomization for excellent idle and tuning
- Technical assistance and tuning data available via phone or email
- 12-month comprehensive warranty
An amazing product and unmatched quality/performance. If your LS is thirsty DW has it covered!
Questions: Shawn (440)417-8451
(email)shawn@importimageracing.com
AIM- ImportImageShawn
GoPro Motorsports Video Cameras Hd/Sd & Accessories Here! Free Shipping!
HD MOTORSPORTS HERO $299? Nope!! Pm for your special price!!!
STD DEF $149.99
ABOUT:
GoPro’s HD Motorsports HERO is the world’s highest performance 1080p HD on board video and still photo racing camera. Professional quality 1080p, 960p, and 720p HD resolutions records the action at 30 frames per second (60 fps in 720p). The HD Motorsports HERO easily mounts to any helmet, motorcycle, ATV, car, plane, jet ski, boat, snowmobile or other vehicle. The camera’s quick-release mounting design makes it easy to re-position the camera around your vehicle for professional quality HD video from several angles.
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
GoPro’s obsession with sound has conquered the wind. At 85 mph on a motorcycle, you’ll enjoy the throaty sound of your motor, not the wind. Inside even the quietest street cars, hear the pull of your motor…not the drone of the wind and road.
The camera can also shoot automatic 5MP time lapse photos at 2/5/10/30 and 60 second intervals during your drive or ride, hands free. Press the shutter button once and record up to 2.5 hours of on board action with poster-print quality photos.
Included are mounts for two helmets and three vehicles, as well as a suction cup for maximum versatility and convenience. Also included is a 1100mAh rechargeable lithium-ion battery that lasts for up to 2.5 hours of constant recording. With optional accessories, you can also plug the camera into a wall outlet, cigarette lighter, or with any USB-compatible power adapter, wire it directly to your vehicle’s electrical system. The battery will charge while you record.
Waterproof to 180’ / 60m and protected from rocks and other hazards thanks to its removable polycarbonate housing. Replacement housings and lens kits are available, making repairs or refurbishing your HD HERO camera affordable and convenient.
WHAT COMES WITH IT?
1 HD HERO Camera (5 megapixel)
1 Rechargable 1100 mAh Lithium-Ion Battery
1 Waterproof Quick-Release Housing (180’/60 m)
3 Flat, 3M™ Adhesive Mounts
2 Curved, 3M™ Adhesive Mounts
2 Quick-Release Buckles
1 Vertical Surface “J-Hook” Buckle
1 Suction Cup Mount
1 Three-Way Pivoting Side Arm Assembly
1 USB Cable
1 Component Video (HDTV) Cable
1 Composite Video + Audio Out Cable
Warranty: One Year
TECH SPECS:
Camera Optics
Lens Type: Fixed Focus (2ft/.6m – ∞), glass
Aperture: f/2.8 (high performance in low-light situations)
Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
Angle of View: 127º wide angle in 1080p mode
Video
HD Video Resolution Modes: (subject to change, pending final firmware release)
1080p = 1920×1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
960p = 1280×960 pixels (4:3), 30 fps, 12 Mbit/s data rate
720p = 1280×720 pixels (16:9), 60 fps, 15 Mbit/s data rate
720p = 1280×720 pixels (16:9), 30 fps, 8 Mbit/s data rate
WVGA = 848×480 pixels (16:9), 60 fps, 8 Mbit/s data rate
Sensor Type: 1/2.5″ HD CMOS, 2.2µm-sized pixels
Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
Exposure Control: Auto with user selectable center weighted average and spot metering settings
White Balance: Auto
Audio
Microphone: Built-in, mono with AGC (automatic gain control)
Audio Format: 48 kHz, AAC audio compression
Resolution: 5 megapixel
Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
Memory: SD card (SDHC), up to 32GB capacity (not included)
Average recording times (using 32GB SD card):
1080p (30 fps): 4h 21m
960p (30 fps): 5h 26m
720p (60 fps): 4h 21
720p (30 fps): 8h 09m
WVGA (60 fps): 8h 09m
Camera Connectors & Cables
PC Connection: USB 2.0 (data connection and battery charging)
HDTV Out: HD NTSC & PAL (component cable incl.)
Audio Out: Combo 2.5mm jack with stereo audio and composite video out
PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
Power & Battery
Battery Type: Rechargeable 1100 mAh lithium-ion
Battery Life: Approx. 2.5 hrs
Charging: via USB to computer or optional power adapter
Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
Depth Rating: Up to 180 feet / 60 meters
Construction: Polycarbonate and stainless steel
Hardware: Stainless steel
Size & Weight
Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
WHAT ELSE IS AVAILABLE!!??
HD HELMET HERO $299? Nope!! Pm for your special price!!
STD DEF 149.99
ROLL BAR MOUNT FOR GO PRO $29.99
HEAD STRAP ACCESSORY $14.99
ADDITIONAL SUCTION CUP MOUNT $29.99
TRIPOD ADAPTOR FOR GOPRO $7.99
GRAB BAG EXTRA QUICK RELEASES, MOUNTS ETC.. $19.99
WE ARE PROUD TO BRING YOU THE LEADER IN AUDIO/VISUAL TECHNOLOGY FOR MOTORSPORTS AND MORE
MOTORSPORTS AND HELMET CAMS
**SHIP FREE FOR LS1TECH MEMBERS**
IN THE LOWER 48 USA
IN THE LOWER 48 USA
IIR MUSCLE OFFERS THE ENTIRE GOPRO LINEUP, BUT HERE ARE SOME OF THE CREAM OF THE CROP
STD DEF $149.99
ABOUT:
WHAT COMES WITH IT?
1 Suction Cup Mount
1 USB Cable
Warranty: One Year
TECH SPECS:
Camera Optics
Video
White Balance: Auto
Audio
Storage
Power & Battery
Size & Weight
STD DEF 149.99
THESE AND SO MANY MORE ACCESSORIES, BATTERIES ETC... ARE AVAILABLE NOW FROM IIR'S MUSCLE DIVISION.
ANY QUESTIONS PM OR EMAIL shawn@importimageracing.com FOR DETAILS.
TIME TO TAKE SOME AMAZING PHOTOS, VIDEOS AND MORE ALL IN ONE SPOT SAFELY FOR YOUR VEHICLE.
CUSTOMERS BE SURE TO SHARE YOUR VIDEOS AND PICS WITH US IN THIS THREAD!
SAMPLE GOPRO HD VIDEO, ALL SHOT WITH GOPRO EQUIPMENT SOLD RIGHT HERE, PIKES PEAK 2011
HELMET CAM, GOES WHERE YOU GO
