The SuperMaxx header GP is a GO!
We're already up to 14 orders so the SuperMaxx group purchase will be going through! Orders can be placed through next Monday (3/29) -
LS1 f-body
Dynatech headers are built using only the best mild steel and stainless materials available. All of our flanges are CNC laser cut and guaranteed to .003”. Laser cutting allows us to offer many variations in port size and shape to insure maximum performance. Dynatech is the only company in the industry to offer a satisfaction guarantee and a one year limited warranty.
Part numbers for the complete header packages are -
115-732300S 1998-'00 SuperMaxx header package
115-732325S 2001-'02 SuperMaxx header package
And for the headers only -
115-732300 1998-'00 SuperMaxx headers only
115-732325 2001-'02 SuperMaxx headers only
C5
DynaTech has updated the connection on their C5 header package. They now use a low profile 4 bolt ball and socket connection where the cats meet up to the headers.
Part numbers for the header packages are -
115-736300S 1998 - 2000 C5/Z06 SuperMaxx header package
115-737300S 2001+ C5/Z06 SuperMaxx header package
And for the headers by themselves -
115-736300 1998 - 2000 C5/Z06 SuperMaxx headers only
115-737300 2001+ C5/Z06 SuperMaxx headers only
Trucks
SuperMaxx Features & Benefits
Heavy-wall aircraft quality stainless steel tubing throughout the system (1 3/4headers, 2 1/2x 3Y-pipe) for outstanding performance and durability.
Extra-thick (.375), laser-CNC-machined header flange for superior gasket sealing.
Factory-style O2 sensor bungs for direct fit and fully ODB-II compatible.
Hi-flow, stainless steel catalytic converters for increased horsepower and torque.
Slip-together union in the Y-pipe assembly allows for easy installation without welding.
Hi-flow merge-style Y-pipe for maximum exhaust flow.
Stainless steel Y-pipe flange retains the factory ball & socket connection.
Unique collector/converter connection utilizes a self-aligning, sintered metal, donut gasket for a long lasting leak-free connection.
Part number 115-841300 covers -
2000-04 1500 series 2WD & 4WD 4.8 and 5.3
2000-04 Avalanche 2WD & 4WD 4.8 and 5.3
2000-04 Suburban 2WD & 4WD 5.3
2000-'04 Tahoe/Yukon 2WD & 4WD 4.8 and 5.3
And 115-841350 is for -
2000-04 2500 series 2WD & 4WD Pick-ups and Suburban 6.0
2000-04 Escalade, Denali 2WD & 4WD 6.0
2003-04 H2
The headers are also available without the highflow Y-pipe with cats -
Long tube 1 3/4" tuned stainless steel header set, with 2 1/2" collectors. Reducer cones have o2 sensor bungs installed. Includes V-8 header set, header gaskets, header bolts and reducer cones.
115-841310 - 2000-'04 4.8, 5.3 and 6.0 Chevy/GMC 1500 SUV/2500
(*Avalanche, Escalade, Suburban, Silverado, H2, Tahoe, Yukon and Denali)
More info can be found in the Group Purchase section of our website. This GP will be wrapping up on Monday, March 29th. Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Have a good day,
Tom
LS1 f-body
C5
Trucks
2003-04 H2
Have a good day,
Tom
The GP pricing is a little to low to post. Just give us a call or e-mail tbyrne@tbyrne.com for pricing.
Are the cats in the catted y-pipe header package easily swapped out? Can straight race pipes be installed in place of the cats (similar to the FLP header system)? If so, does this package include them or are they available for sale?
Thanks
Thanks
Can you purchase the off-road pipes, like in the flp system, and they work on this system like the flp does to make it an off-road or a high flow pipe? Is the pipe used in the flp system to replace the cats the same size as this system?
There aren't any offroads that can be purchased for this package. The Dynatech headers are stainless (some other companys use mild steel). They also use a 4 bolt connector to mate up the cats. Those cats flow very well -
Let me know if you have any other questions.
Tom
Tom
I talked with Greg at Dynatech before I orderes mine about fit, installation issues and ground clearance. He told me they were identical to the FLPs due to the fact that they made the headers for FLP. Except these are stainless instead of ceramic coated.
