Buy HINSON Plug Wires & Heat Boots Get Free NGK Spark Plugs
Hinson Motorsports is proud to offer these new Super Conductor 8.5mm wires. Made in the USA from a 8.5mm spiral core.
Heres How You Get FREE NGK Plugs:
- Add HINSON Standard Length Plug Wires to the Cart
- Add HINSON Plug Wire Heat Boots to Cart
- NGK TR-55 Plugs Will Automatically Appear for FREE
- Checkout
Standard Length 8.5mm Wire in Red
Standard Length 8.5mm Wire in Black
Standard Length 45' Angled Boots in Red
Truck/Long Length 8.5mm Wire in Red
Hinson Motorsports Plug Wire Heat Boots
*Notice how HINSON heat boots cover the entire standard length wire for the best protection.
Pair Your Hinson Motorsport Plug Wires with NGK TR-55 Plugs
tr6 Plugs
I have an 11.1ish 5.7 in an 02 Camaro. I was thinking a tr6 would be a better plug for the combo I have going. What would you guys recommend and could you include those instead?
Thanks,
Doug
Thanks,
Doug
If your N/A usually the TR-55 is the plug of choice, but if you want the TR-6 that is perfectly fine. When you purchase just put in the notes section that you wish to have TR-6 instead.
