AP-Engineering 408 SHIPPED long block special
PSJ Wannabe & Attention Whore
THIS CRATE ENGINE INCLUDES THE PARTS AND SERVICES LISTED BELOW. THESE ENGINES GENERALLY TAKE 4-6 WEEKS FROM TIME OF DEPOSIT TO COMPLETE. IF YOU HAVE ANY QUESTIONS PLEASE FEEL FREE TO GIVE US A CALL AND ASK FOR BRIAN.
6.0 GM BLOCK (NO CORE REQUIRED)
CALLIES 4.000" STROKE FORGED CRANKSHAFT
CALLIES LS1 FORGED H BEAM RODS (LS1 SPECIFIC)
DIAMOND FORGED PISTONS
DIAMOND 4130 CHROMEMOLY WRIST PINS
DIAMOND PROSELECT RING SET (FILE FIT)
FEDERAL MOGUL MAIN BEARINGS (152M)
CLEVITE CONNECTING ROD BEARINGS (CB663H)
ARP MAIN STUDS
ARP HEAD STUDS
PORTED & PREPPED OIL PUMP
CLOYES ADJUSTABLE TIMING CHAIN SET
COMP CAM HYD ROLLER CAM
GM HYD ROLLER LIFTERS W/HOLDERS
TREND CHROMEMOLY PUSHRODS
YELLA TERRA ROCKER ARMS
APE STAGE II 6.0 CYLINDER HEADS (NO CORES NEEDED)
GM MLS HEAD GASKETS
OIL PAN GASKET
COVER GASKETS
FRONT AND REAR CRANK SEALS
This engine is a proven combo. Here is the link to the dyno numbers:
https://ls1tech.com/forums/dynamometer-results-comparisons/170627-ape-408-engine-dyno-results.html
We do NOT need any cores. All you will have to reuse is your covers, or send them to us and we will put them on for free.
Price for this engine is 9999.00 SHIPPED !!
ARP MAIN STUDS
ARP HEAD STUDS
GM MLS HEAD GASKETS
OIL PAN GASKET
COVER GASKETS
