dlove's 414 Powered 00' Z28
Old 03-05-2009, 01:46 PM
  #41
mad_steve's Avatar
Originally Posted by dlove
I have not, yet. I would like to. I plan on doing all of that when I do some tubs in the rear. I think Chris Morales in the drag tech section lost about 75-100lbs in the rear from doing tubs and cutting extra metal out.
That's not bad at all. You going with the Wolfe mini-tub kit?
Old 03-05-2009, 02:51 PM
  #42
dlove's Avatar
I might just do the full tub. As he said he saved a good amount more weight doing that.
Old 03-06-2009, 07:56 AM
  #43
mad_steve's Avatar
damnit boy! lol
Old 03-06-2009, 06:25 PM
  #44
$O$OE's Avatar
so ur cam only ls2 was dipping into the 10's on motor or spray?
Old 03-06-2009, 10:31 PM
  #45
dlove's Avatar
the ls2 went 10.4 @ 128 NA
Old 03-07-2009, 12:12 PM
  #46
SIC LSX's Avatar
from what ive seen
https://ls1tech.com/forums/staff-veh...ed-00-z28.html
Motor setup:
LS2 shortblock
Stock Port L92's,
l76 intake / NW 92mm TB.
LG G6x3 cam
SLP 1 3/4 headers, 12'' turn downs off the headers
ASP Crank Underdrive Pulley
NGK TR6 Spark Plugs, MSD Plug Wires
Full EFI Live SD tune.
Transmission:
Powerglide transmission, built myself.
Circle D- 5C 5000 stall
BMR crossmember
Stock steel Driveshaft
Rear End:
10 bolt, 4.11's,
Suspension:
Custom Welded Subframe Connectors
Custom chromoly 6 point
QA1 R's with Afco 275 springs in front
Profab K member
Madman 1 off solid motor mounts
Madman manule rack
Burkhart 2'' drop spindles
Strange double adjustable rear shocks with v6 springs
SJM Tubular Lower Control Arms with Welded in Relocation Brackets
Madman Torque Arm
Performance Statistics:
N/A best with the LS2.
1/4 Mile: 10.46 @ 128, 1.47 60ft
Race weight is 2800 with him in it.
Old 03-08-2009, 11:28 PM
  #47
dlove's Avatar
Originally Posted by SIC LSX
from what ive seen
Motor setup:
LS2 shortblock
Stock Port L92's,
gmpp intake and 2000cfm tb
231/239 pat g cam
Transmission:
BMR crossmember
Rear End:
10 bolt, 3.73's,
Suspension:
Profab K member
sphon Torque Arm
fixed
Old 03-09-2009, 03:29 PM
  #48
Brad Hutchcraft's Avatar
People, how bad *** is that mini-tub job that mad man did? Lets hear it for a sick looking, clever way of losing some weight! Functional too!
Old 03-09-2009, 05:42 PM
  #49
mad_steve's Avatar
Thanks for the props!
Old 03-14-2009, 11:19 PM
  #50
frito1's Avatar
I'm so sad to hear the bad news..... Your car was my car's roll model
The only good thing is my car is faster than yours right now
Old 03-15-2009, 12:01 AM
  #51
dlove's Avatar
collasped a lifter. Most of them that came out are pretty weak. You can push the plunger in with ease. They are LS7 lifters with about 5k miles on them and happened at about 7k rpm with no pryor signs of an issue. Also the spings are patriot extremes with about 1k miles on them.
Valve hit the piston and the piston is now no where to be found. Put a hole in the sleeve.
Motor is done for. Pics soon.
Old 03-15-2009, 12:34 PM
  #52
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Those pictures are pretty brutal. You have the magical disappearing piston. That's an expensive explosion. I had similar results when my stock engine blew up and trashed the whole thing in my Formula.
What are the plans from here?
Old 03-15-2009, 12:49 PM
  #53
stumprrp's Avatar
dude that sucks! i was so looking forward to the new times! 454lsx from here? lol
Old 03-15-2009, 01:08 PM
  #54
Quaman's Avatar
******* WEAK!! And the weathers just starting to look up for you Kansas boys..Good luck on the new adventure.
Old 03-15-2009, 01:57 PM
  #55
dlove's Avatar
Probably just grab up another ls3.
Old 03-15-2009, 02:14 PM
  #56
stumprrp's Avatar
any reason for ls3 in specific? JW.
Old 03-22-2009, 11:49 PM
  #57
SIK02SS's Avatar
i can't see any pics. i've been thinking about this swap myself....i take it that it's a straight forward swap, nothing needs to be altered/added in the engine bay?
Old 03-23-2009, 12:56 AM
  #58
dlove's Avatar
pics are in the other post....
Old 03-23-2009, 07:34 PM
  #59
Sharpe's Avatar
Wow. Sucks, man.
Old 03-23-2009, 11:56 PM
  #60
dlove's Avatar
I found what did my motor in. The vvt oil pump.
Found a spun bearing in the bad cylinder. Looks like I probably sucked the pan dry.
The extra slop in the rod cause it to come up more in the cylinder and hit the valve.
Total damage:
1 broken valve
3 bent valves
1 missing piston
1 piston broken off the rod
2 bent rods
2 cylinder sleeves with chunks missing
cracked block
camshaft scored on a few lobes
both heads need lots of work
windage tray bent
Crank scored up
Quick Reply: dlove's 414 Powered 00' Z28
