Zune to Alpine CDA-9856
Old 12-28-2008, 11:28 AM
RsSean's Avatar
Default Zune to Alpine CDA-9856
I need some help. I have been on the internet all morning looking on how to hook up my 120 GB Zune to my Alpine head unit.
There is a connector from Alpine for a Ipod, but not a Zune. There is no Aux in or head phone jacks on the this unit either. The only way so far I have got it to work is threw the Xm radio signal. Un plugging the XM and plugging it in to the head phone jack on the Zune.
Does anyone make like a connector that goes from Ipod to Zune so I can hard wire it in?
Thanks
Old 12-28-2008, 11:40 AM
pentavolvo's Avatar
there is no zune type interface, u need to get the alpine auxilary input piece and plug in via that and control everything from ur zune
kca-121b and an rca to headphone cable
http://cgi.ebay.com/Alpine-Ai-Net-to...3%3A1|294%3A50
Old 12-28-2008, 12:04 PM
Dimitri-'s Avatar
No, there is an alpine AInet to AUX that you can hook up. It was about 13 dollars on ebay but i dont think Im gonna use it because the cable is so short I dont think it would reach from behind the HU to the front.. plus I found an ipod so Im just going to keep that in the car all the time and use the cable the HU came with
Old 12-28-2008, 01:03 PM
stealth355tpi's Avatar
i run a zune with a rockford fosgate headunit. its very easy to do and you can pick up what you need at radio shack. you need a cable the has rca's to headphone jack. the only thing is you wont be able to control the zune with the headunit. you'll have to change the songs on the zune. here is what im using.
http://www.radioshack.com/product/in...ductId=2102974
Old 12-28-2008, 05:17 PM
RsSean's Avatar
But don't the RCA cables have to go to a AUX in correct. The head unit only has out no ins.
If that connector above off ebay then to a the radio shack thing may work. Dunno.
Last edited by WhiteBird00; 12-28-2008 at 07:53 PM. Reason: merge consecutive posts
Old 12-28-2008, 10:12 PM
pentavolvo's Avatar
buy the connector i listed (trust me ur radio has the plug) go into the alpine menu and turn the aux on, go to radioshack get a 6 foot rca to 1/8 cable like 6 bucks plug the cable into the adapter on the radio and ur done
this isnt really rocket science
Old 12-29-2008, 05:49 PM
RsSean's Avatar
Sorry it was not clinking in my head at the moment I was reading it. I am getting the stuff tomorrow. Thanks again for all you help guys.
Old 12-29-2008, 08:12 PM
RsSean's Avatar
Ok I went and bought the cables to get this Zune to play and now the Head unit will not go to AUX. It only flips between the Radio and CD. THis is getting really old.
I bought the cable that plugs into the back of the radio, also bought the rca to head phone cable. Plugged it all in and the stupid head unit will not switch to AUX
I read in the owners manual that all you have to do is push the source button and it will switch, but it does not. only between the Radio and CD
NO error messages either, just won't switch
found the switch under the radio to switch it over to intercept the signal for the Zune. Is there a universal channel to use. 87.7 is the best so far, but can not turn the radio above VOL. 4 due to static. Zune is playong on VOL 20.
Old 12-29-2008, 11:17 PM
HMFDZ28's Avatar
Press Menu...... Use the track advance button till the display says AUX In....Turn the rotary **** till it says on.....press Menu again. If you dont do that the AUX will not show in the function menu.... well at least thats what it looks like using the Manual PDF from Alpine's web page.
Old 12-30-2008, 03:51 PM
pentavolvo's Avatar
yeah it has nothing to do with a switch on the bottom at all go into the menu and turn the AUX on its in ur manual
Old 12-30-2008, 06:28 PM
RsSean's Avatar
Ok I did that and it will play on AUX, but the volume sucks. It is maxxed out on the zune and maxxed out on the player, and you can barley here it. It only sounds like it is coming out of the the froont door speakers, and the front tweeters. The only time you can here it is with the car at idle. The car is not loud at all either.
Is there something I can do to get it to be louder? or play thur the whole car like a normal song.
Old 12-30-2008, 08:33 PM
Dimitri-'s Avatar
Hmm I remember when I hooked up my Zune using the radio transmitter crap on the stock HU and I had the volume maxxed on the zune and it wasnt very loud but the HU put in the rest of the volume and made it decent.
It could be because of the rca connections on all that, ive never used them to hook up an aux, too many dif wires where quality is lost. I would almost guarantee it wouldnt be like that if you just had the AInet>Aux hookup but I dono I didnt even hook up mine
Old 12-30-2008, 08:48 PM
HMFDZ28's Avatar
The Zune's output is really dependent on the volume the song was recorded.... Better off having the zune at like 17 and raising the volume on the Deck. Thats just my experience playing my Zune audio and Video through my Pioneer AVH-P4000DVD
Old 12-30-2008, 10:21 PM
pentavolvo's Avatar
something is wrong then u got a loose connection maybe, did u put that switch back on bottom of radio to where it shoudl be
and it shoudl come out of all ur speakers
Old 01-01-2009, 09:10 AM
RsSean's Avatar
Well I have not got back to the radio issue yet. Be caught up with family for new year. I am going to pull the radio out this morning and switch it back and see if that will make the difference that I need.
I just went out and switched the head unit back to normal and it works perfectly.
Thanks a millon guys.
Old 01-01-2009, 12:39 PM
pentavolvo's Avatar
glad u got it going man
Old 01-02-2009, 06:49 AM
SSweet97's Avatar
I have the Alpine CDA-9887 and my unit has the Ipod hook-up, can I use the Ipod cord on my Zune?
Old 01-02-2009, 10:52 PM
RsSean's Avatar
NO, you have to do what I just did. Look at the post with the link to ebay, buy that cable. That cable plugs into the Ai-net plug in the back of the radio.
Then after you have that plugged in. You need to buy the RCA adapter that plugs into the Ai-net cable. Then plug it into the Zune. Switch the source to AUX and listen away.
Old 01-03-2009, 08:20 AM
SSweet97's Avatar
Thanks Sean. Where did you buy the RCA adapter? If you have the part #, that would be cool also.
Old 01-03-2009, 08:33 AM
SSweet97's Avatar
Got the part #'s, thanks guy's, you rock.
Quick Reply: Zune to Alpine CDA-9856
