Mounting of Subthump amp rack
Old 04-24-2009, 10:35 PM
Intercooler2's Avatar
Default Mounting of Subthump amp rack
Well mine was put in the back with just a couple of screws and it has fallen now.
So here was my plan!
Get a 12" drill bit, hold that sucker in place (after I take the tail lights out) and bore a hole on each side through the wood and metal at the back. Put a proper length bolt through from the outside with a nut on the inside of the metal, slide the amp rack on and use two fancy nuts to hold it in place. Of course I would seal the bolt and all. This way I could take it out if need be and it will never fall again.
Thoughts?
Old 05-01-2009, 11:48 AM
Anyone? I want to just drill through this sucker. Anyone have thoughts on doing it this way?
Old 05-01-2009, 07:13 PM
99Bluz28's Avatar
I don't see a problem as long as you use some washers, and seal it up good!
Go for it !
Old 05-01-2009, 07:27 PM
I hate being the first LOL
Old 05-12-2009, 01:15 AM
Snake_Skinner's Avatar
^ theres a first for everything n let us know how it goes cause ill be 2nd if it all goes well
