Ground question
Old 05-11-2009, 08:09 PM
Vicinity's Avatar
Default Ground question
Can I ground using this seat bolt?
Also, how far can I drill into the "hump" that separates the t-top storage spot from the backseats (where the axle and I guess gas tank is)?
Old 05-11-2009, 09:45 PM
Vicinity's Avatar
Bump, I hate being "that guy" that bumps his **** right away, but I need an answer soon.
Old 05-11-2009, 10:06 PM
pentavolvo's Avatar
clean up the paint arond it and ground to it
as far as drilling through that hump i would look under the car and see where it places u, im pretty sure anywhere on that hump puts u at the gas tank
Old 05-11-2009, 11:36 PM
Engine_HP's Avatar
Old 05-13-2009, 04:42 AM
Vicinity's Avatar
Are you sure? I've seen people put amps there before and I'm pretty sure they secured them. I'm really skeptical, though.
Old 05-13-2009, 05:24 AM
flippincamaro's Avatar
Yea, man under that hump is the fuel tank.You dont want to drill there, if you do just use very small tapping screws. The tank is about a 1/2 inch under the metal.
Old 05-13-2009, 05:26 AM
Vicinity's Avatar
Damn... how can I mount my amp then? Any ideas?
Old 05-13-2009, 05:40 AM
Yup, I made a plate for mine to sit on in my other car when i had it. It went from one side of the back to the other.
Old 05-13-2009, 05:52 AM
95highline's Avatar
take a peice of 1/4" wood (or something close) and pull the carpet back and glue the wood down with silocon or some for of adhesive like that. you could also drill hole into the wood and have bolts comming through the bottom to the top which would match your amp's mounting or use small wood screws that wont go through to far.
Old 05-13-2009, 07:50 AM
dragonrage's Avatar
3 words: industrial strength velcro
That ground point will work, but why would you use it? Use the large upper bolt of one of the rear seatbelts.
Old 05-13-2009, 02:30 PM
Rockstar
Johnny-LT1-runner's Avatar
Yeah, the ground will work, i've got mine grounded on the rear passenger seat retaining bolt.
Old 05-13-2009, 02:44 PM
Engine_HP's Avatar
skrew the amp to the carpet.
Old 05-13-2009, 04:00 PM
Vicinity's Avatar
Those are both good ideas.
Thanks!
Old 05-13-2009, 10:07 PM
RedZ99's Avatar
Just run in in a separate ground wire?
