Running alpine Type R coax on monsoon amp?
1 Post
I have some alpine type-r coaxial speakers. Just changed my headunit, i know there is a change in resistance. Btw, anyone know how well they will work?
Ok my main question. I realize there is a separate channel for the tweater. Does the mid channel in the doors have the high frequencies or will I be missing them by not using the tweeter channel?
Ungrounded Moderator
Yes your Alpine coaxials will work although you will be giving up power by only using one of the two channels in each door. The best way to handle that is to modify the coaxials so that they work like components. Cut the fine wires that go from the speaker terminals to the tweeter and then connect the car's tweeter wires to those cut wires and the car's mid wires to the speaker terminals.
The door mid channels are full-range signal. The tweeter wires are high pass filtered.
