What speakers to go with when keeping the factory head unit and amp?
I have at least one blown speaker possibly more in my T/A. I am planning on keeping the stock head unit and amp for now but will upgrade both in the future. Anyone have any good experience with direct replacement speakers that sound good and have good bass. I am thinking of going with Memphis audio since the local system shop has them in stock. I am also thinking of going with midbass woofers in the sail panels to help with the bass aspect. It should only get better when I change amps. What does everyone recommend?
if you haven't read the sticky you should do that first, then check out keeaudio.com, i replaced my sail panel speakers with his bazooka DVCs, they're not out of this world or anything but they sound pretty good. i'm happy with them so far and he's great to do business with. i heard some memphis 6.5 inch components at a local place and i thought they sounded great for the price ($125) most people on here love their CDT replacement stuff, but i've never actually heard them, good luck.... idk if all TAs have the monsoon system so make sure you know what you need, best advice i have is do plenty of research before spending your hard earned cash
I read the sticky but just trying to get some opinions from people who have changed them out. My T/A has 4 ohm speakers in the sail panels. I will look into key Audio
most of the bass comes from the sail panels in that setup, but the bass should be somewhat improved. I have the Bazookas in my Firebird sail panels, and it is much better over stock.
If you have a TA then your door speakers are component not coaxial. I have my CDT component here waiting to be installed. From what I have read on this site everyone loves them. I also have the bazookas installed right now and they do sound good. Contact Ian at keeaudio.com his packages are based solely on the F-bodies so you can't go wrong.
I just heard from a few people that the premium package isnt the way to go with the factory head unit and amp. I am going to try and change my order to the package with the bazooka sail speaker and try and upgrade from the JVC 4inch to the CDT 4 inch for the rear
The bazookas are for the trans am not the camaro. The camaro only have a single voice coil speaker the trans am had dual voice coil. So if using all factory wiring and head unit the bazookas won't be plug and play you will have two jump the voice coils to get a 2ohm load on them. Google wiring dvc subwoofers for the wiring diagrams.
Ungrounded Moderator
So Bazooka 6.5" or CDT 6.5" for the sails? and if the CDT, then which model (misbass) would be recommended since theres 4 slightly different models? using the stock monsoon HU and amp.
Or any other suggestions besides bazooka or CDT? car is an '01 trans am
I just recived my Bazooka 6.5's today from Kee Audio, just waiting for the CDT speakers to get here and I will install them this weekend and let you know how it sounds together. I went with the Bazookas because they are DVC and should be a great uprgrade for the sail panel speakers.
