Monsoon radio headunit switch issue
so im swapping out my monsoon headunit for a DVD player and i got the mount kit and wiring harness and antenna adapter and all is ok with the way it fits but when you turn the key the new radio will turn on and appear to function ok but now i habe NO SOUND through my speakers the wiring harness has 8 speaker wires and 2 for power and one ground is there supposed to be a power wire to turn on the amp i didnt see on in the FAQ section but with the new radio wired up i have no sound at all please help
2002 z28 6 speed monsoon system
amp has no power. I think the grey wire is remote power for amp. if that is hooked up then check the new headunit to see if it has setting for remote amps. I had one that came from the factory with that switched off in settings and as soon as I set to on bam amps fired up.
