What goes in the passenger side rear wheel well? Big connector missing black box
I just bought a 02 ws6 and when I was going through the car I was checking for the spare and jack which wasn't present. When I looked around in the passenger side rear wheel well there was a huge connector laying there with nothing connected to it. Upon further investigating I looked at another Fbdoy and that connector connected to a descent size metal black box that bolts towards the top of the wheel well. My question is what is this box? and what does it do? and do I need it for my own safety?
Something doesn't sound right here. Black connector, unused, rear wheel well. Wouldn't that be for the OE CD changer and I thought it was on the drivers side. If yours is the passenger side maybe they moved it over or it's an add on?
Ungrounded Moderator
The only large connector on the right side would be for the Monsoon amp. You can check by comparing it to the diagram and pin-out in the Monsoon FAQ sticky at the top of the section.
And don't worry about being told that the Monsoon amp sucks. Some people just repeat what they've heard without really knowing. The Monsoon system gets a bad reputation because the head units are just ordinary Delco radios that produce lots of distortion and the speakers are made of cheap materials (although they don't sound too bad until they blow). You can get a replacement Monsoon amp fairly cheap and it will produce clean amplification into eight channels provided it gets a clean input signal. If all your wiring is intact, it is an option you might want to consider.
