Biggest battery that can fit in a 1999 Camaro Z28
I would go out and measure myself however the car is in the shop. Anyways I have a chance to get a XS Power D3400 for real cheap and I need to know if this battery will fit just as is or even fit if some slight modifications need to be done. The measurements are:
Weight Lbs. - 46.00
Weight Kgs. – 20.85
Length – 10.24 in
Height – 7.20 in
Width – 6.65 in
MAX Amps – 3300
Ah – 67
Thanks Guys
Weight Lbs. - 46.00
Weight Kgs. – 20.85
Length – 10.24 in
Height – 7.20 in
Width – 6.65 in
MAX Amps – 3300
Ah – 67
Thanks Guys
Ungrounded Moderator
Here is the BCI battery group size chart: http://www.rtpnet.org/teaa/bcigroup.html
F-bodies take group 75/25 batteries which are just over 9 inches long. I have heard of people stuffing group 34/78 batteries in without too much difficulty but I've never tried it myself.
You could always do a rear battery conversion and fit something crazy in. I just swapped my G8's battery with an even larger Deka 9A31 (which is an awesome battery - not sure why people would buy other brands over Deka, because Deka is great for car audio, reliable, and much more reasonably priced as well)
Dimensions:
Length 13"
Width 6 3/4"
Height 9 1/2"
Other than that, I don't remember my Camaro (which was also a 99 Z28) having enough room to fit that much bigger a battery than stock...
Dimensions:
Length 13"
Width 6 3/4"
Height 9 1/2"
hmmm...well if you've heard of people stuffing group 34's in I should be fine then. Because the XS D3400 is a group 34. As far as a rear battery conversion, out of the question with a driver and passenger side stealth box. Also keeping trunk open for t-tops. Deka is nice yes, however there are some differences. As far as with XS there D3400 is 20lbs. lighter, alot smaller, and I like the look alot better lol. Price on a Deka is alot better compared to XS however, there is no way I can fit a group 31 in the oem spot lol.
Dimensions:
Length 13"
Width 6 3/4"
Height 9 1/2"
Dimensions:
Length 13"
Width 6 3/4"
Height 9 1/2"
