DEI 561T Remote Start
Old 04-16-2012, 04:37 PM
loyolacub68's Avatar
Default DEI 561T Remote Start
What is the best way to bypass VATs so it is only bypassed when the remote start engages? I have the module from eBay but I don't want to completely disable this function.
Also, does anyone have a good wiring diagram for the ignition switch harness?
Thanks.
Old 04-20-2012, 09:38 AM
tecmec's Avatar
DPDT relay. Center connections going to the PCM. NC connections going to the connector in the steering column. NO connections going to a resistor (or combination of resistors) that matches the resistor in your key.
Connect the relay coil to the ignition disable output on the starter. [Strongly] consider adding a diode across the coil to protect the starter outputs (1N4001 - 1N4007 family would do).
Quick Reply: DEI 561T Remote Start
