hooking up sirius reciever to h/u
does the sirius reciver hook up to the head unit the same way as the xm unit would? i dont want to use the fm transmitter, so what do i need to make it work? i saw a thread where it was done with xm by using the gm9-aux and cables to the reciever. has anyone done this with the sirius unit yet. should i just use the fm modulator. sorry i'm a tard when it comes to electronics
is it worth it to use the gm9-aux and cables or should i just use the fm modulator? also what cables would i need to go from the aux to the reciever. i have been searchin the web all day and cant really find any answers
Copy & Paste Moderator
WhiteBird00 & Nova5 covered it.
The GM9-AUX provides RCA AUX-IN.
You can connect any audio source you want into the RCA.
(XM, Sirius, MP3 Player, Walkman, .......whatever)
The RCA AUX-IN will sound much better than the FM-Transmitter and you dont have to worry about static or "losing" the station.
My Install:
https://ls1tech.com/forums/showpost....49&postcount=2
https://ls1tech.com/forums/showpost....03&postcount=2
https://ls1tech.com/forums/showpost....57&postcount=4
My Install:
