System Setup Question
How do i add a amp wire to my set of wires that i have in my camaro connecting the head unit to the stock audio setup so that i can hook up my amp and subs?
there is an adapter you can buy to put in there. It is plug and play. It allows to have a set of RCA's out for the amp.
You will need to run your own power and ground wires. As far as the remote wire for the amp turn on, you are going to have to run it from the headunit if you have a Camaro.
ya i have an after market head unit to connect the amp 2 RCA audio cables but im asking about the wire labeled AMP how can i get power to the amp if i don't have a wire in my wire harness to connect it to?
Are you talking about the blue wire on the head unit. If so then that's the remote turn on wire. You have to run that back to the amp to the REM spot. It just turns the amp on when the radio is on so 18g wire will be fine.
