proper way to wire a line lock?
I have been searching and came up with nothing. I rember reading somewhere on here the proper way to wire a line lock. I want this info so i can properly do mine. thanks
Need to run a relay. I tapped into the AIR fuse (AIR system is removed) for the relay's main power. The activation switch needs to be momentary, meaning when you release your finger from the switch, the solenoid lets go. This is an NHRA/IHRA-mandated safety compliance rule. The switch needs to provide power to the signal wire on the relay via a fused/switched power source. I'm using my factory ASR switch (ASR removed) as my line lock button.
Originally Posted by DuronClocker
Factory ASR switch is momentary. If you've removed that system, you can use that switch. I'm going to order up another fog light switch and ASR switch for my nitrous arm and purge buttons/switches.
