Help with ac/heat
Old 09-04-2007, 09:20 PM
DJB
12 Second club
DJB's Avatar
Default Help with ac/heat
Ok I put a motor in my car and I broke one of the ac lines. I got the new line and regarged the system when I got the car running. Now no matter what setting I put it on it will only blow out the floor. It will not blow out the vents. So my quetion is do I have a bad blower motor? I thought if I had a bad blower motor that it would not blow out period.
Old 09-04-2007, 09:41 PM
SparkyJJO's Avatar
nope not the motor, if it is blowing then that is fine. There are directional "paddles" so to speak inside the ductwork to direct air up, down, or whatever. They are either controlled by vacuum or electric, not sure which but I'm guessing vacuum. Which then if you forgot to hook it up to the engine vacuum system then it won't change.
Old 09-04-2007, 09:45 PM
DJB
12 Second club
DJB's Avatar
If so don't you think it woud be electric since you have to turn a switch(the ****).
Old 09-04-2007, 09:57 PM
SparkyJJO's Avatar
Those ***** aren't always electric, they can be vacuum. I know it was in my old car. Only the fan speed was electric, the other two were vacuum lines. Now that was also an old 93 ford and I haven't examined the climate controls on my 98 camaro (I'll check it when I put my HU in) but I don't see why it wouldn't be vacuum.
I can check tomorrow possibly on mine whether or not it is vacuum or electrical.
Old 09-04-2007, 10:02 PM
DJB
12 Second club
DJB's Avatar
Ok thanks
Old 09-04-2007, 11:24 PM
00formLs1's Avatar
sounds like a vacuum
Old 09-05-2007, 03:30 PM
DJB
12 Second club
DJB's Avatar
The small vacum line behind the intake was off. As soon as I plugged it in the air was blowing out the vents. Thanks guys.
Old 09-06-2007, 07:27 AM
SparkyJJO's Avatar
Sorry I forgot to check yesterday, I just checked and it looks like vacuum lines. But I see that you got it fixed already, that's good
