Theftlock not lighting on dash, but on radio
My theftlock light does not light on the dash, but will flash on the radio. How can i test this? Is it a bulb that can be replaced?
Unlock the car, pop the hatch but don't lift it. Make sure the dome lights go out (to ensure the car thinks the hatch is closed so the alarm will set). Hit the lock on your key fob. Wait a minute or two, then lift the hatch open. If the alarm blares then you know it is just the LED isn't working on your dash for some reason. If it doesn't then your alarm system isn't working right.
Ungrounded Moderator
The light on the radio and the one on the dash are totally unrelated. The radio LED is for the TheftLock - a feature that is supposed to prevent the radio from being used in another vehicle (it locks up the radio once power is removed). The LED on the dash is for the vehicle's content theft deterrent system (a very basic car alarm).
Testing is even easier than suggested above. Just close all the doors and lock them using the remote key fob. Then unlock the door using the key instead of the remote. When you open the door the alarm should sound.
