took the z28 to the track for a baseline. how'd i do?
went to cecil for test and tune. the DA according to dragtimes was ~+1500
heres my setup:
LID and HP Tuned by me
1st run got 2.06 sixty foot at 32psi of tire pressure 13.28@106
corrected based on DA would be 13.05@108
AFR was 12.6:1 but got progressively richer getting into 3rd which was at 12.05:1
2nd run got similar sixty at 2.08 but dropped the tire pressure to 26psi and slightly lean the 9K hz frequency by 1%. got 13.35@105 with AFR steady in ~12.4:1
3rd and 4th run i leaned it out again by 1% and got 13.3s@104 and 103.91 with AFR 12.8:1
so for some reason it runs slower as it gets leaner? i have a wideband in the passenger O2 bung running OLMAF. timing's at 23* and from my research is max for nearly stock and on stock manifolds.
my next upgrade will be a stall, maybe 3600?
also how'd i do? when it shifted into 3rd was around 99-101mph on stock 2.73 gears.
heres my setup:
You did well. Pretty average times for an almost stock LS1 Fbody.
However, in a couple hours, you'll have some serious nuthuggers in here tell you that your almost stock setup is complete **** and that you should have went with their stock setup instead so you can run 10s bone stock.
Good runs.
Good runs.
Those times are pretty typical for stock stall and 2:73 gears (swap in some 3:23's or 3:73's if you can find them cheap) I would run more than 23 degrees timing also, I ran 28 degrees on my old bolt-on Z28 and leaned it out. It took me to 11.40's with stall, 3:23 gears, weight reduction, and not even full bolt-ons.
You're on the right track with a stall, don't be afraid to go with a higher stall. I'd recommend FTI, I got a 3800 and it performed great and was still very streetable.
Seeing as how I only run 13.3 107 on 285 N555 with a 2.1 full exhaust true duels and full intake (ls6) with 3.42 gears you're doing alright. First shifts at 5,500 not 6 so it bogs and is slow
Edit: or are you the guy that says your car is slower than stock with all those mods?
headers, stall, tire, edit you're tune to add timing and bump the shift points to ~6100 and you'll easily shave a second off your ET.
If you havent already done them I advise doing all the "free mods" I think they're listed in the sticky FAQ.
Free Ram air, descreen MAF, TB coolant bypass, Free weight reduction, etc...
