How fast are f-bodys?
I heard they have a governer set at 162mph. Mine has no top speed limit... just wondering how fast I'd go. How fast are your cars? Got mine up to 160 and had to slow down.
fbodys without zr tires from the factory are limiter to around 110 or 120...whatever the tires allow for top speed. with zr tires...its around 155 or 160..i forget. you have to also know that the speedo is off a lil...so if you have it pinned at 155....your probably going between 145-150. you can remove the speed limiter with tuning though.
I don't know what the % of accuracy is for the speedo at high speeds, but I've had mine past 155 on the dial plus and extra 500 rpms. Figuring the Speedometer becomes less accurate at higher speeds, I think I was around 153 to 160.
O.K. I did some research on this over at F-Body.org
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear
500 4 7 12 17
600 5 9 14 20
700 5 10 17 24
800 6 12 19 27
900 7 13 21 30
1000 8 15 24 34
1100 8 16 26 37
1200 9 17 28 40
1300 10 19 31 44
1400 11 20 33 47
1500 12 22 35 51
1600 12 23 38 54
1700 13 25 40 57
1800 14 26 43 61
1900 15 28 45 64
2000 15 29 47 67
2100 16 31 50 71
2200 17 32 52 74
2300 18 34 54 78
2400 19 35 57 81
2500 19 36 59 84
2600 20 38 61 88
2700 21 39 64 91
2800 22 41 66 94
2900 22 42 69 98
3000 23 44 71 101
3100 24 45 73 105
3200 25 47 76 108
3300 25 48 78 111
3400 26 50 80 115
3500 27 51 83 118
3600 28 52 85 121
3700 29 54 87 125
3800 29 55 90 128
3900 30 57 92 132
4000 31 58 94 135
4100 32 60 97 138
4200 32 61 99 142
4300 33 63 102 145
4400 34 64 104 148
4500 35 66 106 152
4600 36 67 109 155
4700 36 69 111 159
4800 37 70 113 162
4900 38 71 116 165
5000 39 73 118 169
5100 39 74 120 172
5200 40 76 123 175
5300 41 77 125 179
5400 42 79 128 182
5500 42 80 130 186
5600 43 82 132 189
5700 44 83 135 192
5800 45 85 137 196
5900 46 86 139 199
6000 46 87 142 202
Though I can't recall if I got anywhere near redline in Fourth when I did my top speed run
500 4 7 12 17
600 5 9 14 20
700 5 10 17 24
800 6 12 19 27
900 7 13 21 30
1000 8 15 24 34
1100 8 16 26 37
1200 9 17 28 40
1300 10 19 31 44
1400 11 20 33 47
1500 12 22 35 51
1600 12 23 38 54
1700 13 25 40 57
1800 14 26 43 61
1900 15 28 45 64
2000 15 29 47 67
2100 16 31 50 71
2200 17 32 52 74
2300 18 34 54 78
2400 19 35 57 81
2500 19 36 59 84
2600 20 38 61 88
2700 21 39 64 91
2800 22 41 66 94
2900 22 42 69 98
3000 23 44 71 101
3100 24 45 73 105
3200 25 47 76 108
3300 25 48 78 111
3400 26 50 80 115
3500 27 51 83 118
3600 28 52 85 121
3700 29 54 87 125
3800 29 55 90 128
3900 30 57 92 132
4000 31 58 94 135
4100 32 60 97 138
4200 32 61 99 142
4300 33 63 102 145
4400 34 64 104 148
4500 35 66 106 152
4600 36 67 109 155
4700 36 69 111 159
4800 37 70 113 162
4900 38 71 116 165
5000 39 73 118 169
5100 39 74 120 172
5200 40 76 123 175
5300 41 77 125 179
5400 42 79 128 182
5500 42 80 130 186
5600 43 82 132 189
5700 44 83 135 192
5800 45 85 137 196
5900 46 86 139 199
6000 46 87 142 202
Originally Posted by 2edybrd
Well...I guess you could make the ASSumption that that would be an A4.
Im not sure what these numbers really are. theyre way too high to be fourth gear in an M6, and way too low to be fourth gear in an A4... I guess it probably is an a4 after all, but with a non stock rear diff ratio. I just dont feel like trying every combo out right now.
Originally Posted by OdessitPashka
Mine is limited to 115mph! So annoying!!! Anyone has a programmer that can remove it for me???
Well golly, I sure do apologize for using my old TA as an example. I guess if you were actually curious, you could go to f-body.org and plug your numbers into the calculator they provide instead of being patronizing schmucks
It's too late for apologies. I have to hunt you down and kill your fish now...but first I must find the fishy.
Bring it sucka! My leaky pinion seal will create an oil slick that will spin you out into a telephone pole! The burning oil from my ring blowby and wornout valveseals will create a smokescreen, as will the tiresmoke for my severely traction limited all seasons. Then the pig rich fumes will blind you thanks to my homegrown tune. Then the clutch smoke (from my inability to properly drive my car) will distract you before it finally grenades sending shrapnel out to blow out your tires. Lastly, my precariously worn rear brake pads will be dropped where they will bounce down the road and wedge themselves squarely in your cars piggy nostrils choking your car out.
Originally Posted by SSilverSSurfer
come to houston and get it tuned by the big boys...
man i thought you ls1 guys gonna be far ahead of me but nope im in there with the top speed. I had my 96 Formula M6 up at 155 (speedometer topped) and rpm was still growing(so i guess it was still accelarating). Next time ill take the navigation to be more exact. All i have is a CAI
dont you guys have any roads which are safe for topping out?
i had two lanes and about 10 miles straight road
