double adj torque arm vs lca relo's
this may be a really dumb *** question, but if ur car is lowered and u plan on doing the adj ta is there really a need to do the lca relo's too?
i would say yes they are still needed i would even say that the relo's might do more for traction than the aj t/a.
i have both and i can say that the relo's helped more but even with all that i still had traction problems so the best thing for traction is your tires.
i went from falken street tires to nitto drags and it was night and day.
LS1Tech Premium Sponsor
http://www.bmrfabrication.com/F4.htm
You would not need adjustable control arms if the vehicle is lowered.. like mentioned we do however recommend the control arm relocation brackets which will work with non adjustable controls. These allow you to lower the vehicle but still maintain the control arm at the correct angle and prevent any traction loss. With out the relocation brackets lowering the vehicle may result in additional traction loss.
If you have any questions please ask and I will be glad to help.
Thank you!
Ryan
I know that UMI recommends not getting adjustable, and I respect their opinion. However, consider this:
You are already going to be spending money on the arms, why not shell out some more coin and get their single adjustable. They have two advantages over their non-adjustable: First, the rod end allows articulation, which will make your car handle better. Second, the adjustment allows the alignment shop (or you for that matter) to align the wheels front to rear. Just another way to fine tune your suspension.
And if you lower the car, the relocation brackets are a must.
No you would not need adjustable control arms on a lowered car... I would recommend a adjustable panhard bar though and if traction is a concern a set of control arm relocation brackets.
There is some cases when adjustable control arms are needed and used like mentioned but lowering the car will not effect the length.
If I can help anymore please ask. Thank you!
Ryan
Ryan
While I agree with Ryan from UMI, I went with ADJ LCAs and PHB because I would raher by something once and know if I need to ADJ it I can than having to buy something twice.
It's always better to buy something and not necessarily need it's feature, than buy something and then have to buy the other model.....because the one you have won't work....
Just a thought.
Just a thought.
Just a thought.
Just a thought.
If someone calls in and speaks with a tech rep we try to go over all that with them and there future possibilities to prevent this. E-mail, PMs and posting is harder to get all the information across.
Ryan
The biggest issue I have with the non-adjustable LCAs is that you are assuming that the wheels were aligned front to rear correctly at the factory. Well, I thought so about left to right also until I measured it. The passenger's side stuck out 13/16" more than the driver's side. One UMI single adjustable PHB and two adjustments later, they now are the same on both sides.
I haven't measured front to rear yet, but I have no more faith that it is correct either. Perhaps the customer should measure before making a purchase, so they get the proper part the first time?
Do you drag race? Then getting them would be wise. The angle of the ctrl arms caused by lowering the car hinders straight line traction.
Do you drive easy on the street for a daily driver? Then you don't need them. Waste of money in my opinion here.
Do you like to rip burnouts on the street and get wheel hop? Then relo's would help prevent wheel hop. Shocks will too.
Do you autox or road race? The angle caused by lowering is sort of good for racing in my opinion and preference. Depending on the angle if upward or downward has an effect on the axle pointing slight left or right when the car rolls in a turn. That's the super basic explaination here without going into any detail... (I'm lazy) so in this case... no you don't need them here either
