LCA Relocation brackets
I plan on lowering my car in the spring time. I am getting lca and a panhard bar for Christmas. After doing some research people say that when you lower your car you need lca relocation brackets so the suspension geometry stays correct. I have a simple question, is there any difference between bolt on and weld on? Is it necessary to have one or the other?
Most prefer bolt-in because of simplicity. plus i's easier to line it up since it bolts on 2 different ways.
I have one for sale. UMI relo bracket black and brand new, never installed.
LS1Tech Premium Sponsor
Yes you will need the relocation brackets to correct the control arm geometry. If you have an aftermarket rearend you will need the weld ons. If you still have the stock rearend the bolt ons are fine. We happen to be having a 25% off christmas sale. The weld ons are $59.96, bolt ons $97.46. If you need a set give one of our distibutors a call or you can call us directly. The sale end Dec 24th.
Thanks for the replies, I knew there was something about the rear ends, but mine is stock so I don't have to worry for now. Will the BMR relocation brackets work with umi lca?
Yes they will work with the UMI lca.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
1. Getting from point A to point B and not ripping burnouts... Definitely not.. waste of money
2. Daily driver but want to rip burnouts and getting wheel hop.. Sure.. good modification for fixing wheel hop
3. For handling, autox, or turn racing applications then definitely no.. relos will make the car behave much differently in many different situations for the worse
4. Drag racing... Yes great modification even if you don't get wheel hop. Puts wheel power down to the pavement.
Hmm that is interesting. I really do not do much drag racing, I would rather have a better handling car honestly. Why would it be negative for autox situations?
In all honesty it depends on the lca angle.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Depends on what you want to do with the car all in all. Definitely don't need relos. But a lot of people get them because lots of people like our type of car for drag racing, doing burnouts, etc.. aka situations that cause wheel hop, which is why a lot of people get them after lowering their car.
Correct me if I am wrong by all means, but with the bolt in lca relo brackets, could you not use one setting for drag to reduce the wheel hop, and then change the setting for carving corners and therefore not see any adverse effects? I mean, it's one bolt on each side, and can't be that hard to change once on the car.
I'm not saying all autox/road racers don't like them. I think it depends on how one wants their car to drive. Some people try to use them to make the arms perfectly parallel. As far as I know though, it's pretty tough to make it absolutely parallel and I think some have drilled an extra hole before to get them parallel. I have enough oversteer without the relo's so I def don't need the angle fixed.
