sqeeky brakes issue please help
Old 01-03-2009, 01:30 AM
NeedaV8foundation's Avatar
Default sqeeky brakes issue please help
so i had replaced the complete front brake setup on my car, i got new calipers from napa with ceramic pads and rotors. a couple months ago i was getting a really bad sqeek from the front left brake, i ended up taking off the caliper and noticed that it was wearing unevenly on the rotor. napa replaced their pads under warranty and i machined the rotors down. the squeek went away up until about a week ago and it started coming back, it only happens when im light on the brakes
anyone got any ideas?
Old 01-03-2009, 12:49 PM
Save the manuals!
wssix99's Avatar
I had the same symptom when my wheel bearings/hubs were starting to go bad. My original factory hubs only lasted 70K miles for me.
Old 01-03-2009, 06:13 PM
SS SLP2's Avatar
need to heat cycle brakes - needed if replacing pads or rotors, eather or both,
make 8-10 sllooowww stops from 15-20 mph rolling free between each stop to allow cool down, then 8-10 sllooowww stops from 45-50 rolling free between stops to allow cooling, after the above you may misstreet brakes. besure and use "good" pads, I would suggest OE or Wagnor thermo quit, good pads will cost at wholesale50-70, retaile 100+
good luck, Johnny
Old 01-03-2009, 06:34 PM
GMRL's Avatar
I learned a neat trick on squeaky brakes.
If the pads are good and the rotors are fresh and your still getting noise try this.
Go to the parts store and get a tube of "Valve grinding compund"
Rub some on both sides of the rotors and take it for drive and do a couple hard stops. Ive done it on several cars and its worked everytime.
Old 01-04-2009, 02:58 PM
doesnt that trash your brakes?
