DIY front coilovers
Old 02-05-2009, 01:23 PM
2002z28ssconv's Avatar
Default DIY front coilovers
Has anyone ever done DIY front coilovers on their 4th gen F-Body?
I've done it numerous times on the struts of my other play cars but never heard it done on FBods before.
My car sits a smidge ~3/4" lower on the front right side. I bent it up pretty good in 2004. But it was close enough that alignments have never been a problem. But I need to get it straight. I figure coilovers will be the easiest method...
Old 02-05-2009, 03:55 PM
mitchntx's Avatar
http://www.daymotorsports.com/produc...S-FOR-BILSTEIN
http://www.daymotorsports.com/produc...L_OVER_SPRINGS
And I run these on the rear ...
http://www.daymotorsports.com/produc...L-REAR-SPRINGS
Any rate or ride height I want. I use 8" free height springs on the front and 11" on the rear using the factory spring rubber.
Old 02-05-2009, 04:16 PM
therealcreeper's Avatar
many many many 4th gens sit lower on the passenger side. might not be bent up.
Old 02-05-2009, 04:19 PM
Ironhead's Avatar
4th gen front ends are coilovers straight from the factory.
If you are discussing the installation of adjustable aftermarket components, Ground Control is a good place to start.
Old 02-05-2009, 11:36 PM
integraxtc's Avatar
Yes, coilover sleeves.
I'm thinking about GC myself.
Old 02-06-2009, 01:24 AM
99Bluz28's Avatar
I've got some GC sleeves/spring seats, and springs!
https://ls1tech.com/forums/western-c...n-goodies.html
Old 02-09-2009, 09:53 AM
These were exactly what I was taliking about...
Thanks Mitch! Any idea how long the springs should be? I want about 450lb springs FWIW.
And as far as I'm concerned, GC's are way too expensive if I can put sleeves and custom springs on for ~$200. All I want is to be able to adjust ride height.
Last edited by 2002z28ssconv; 02-09-2009 at 09:56 AM. Reason: Spelling errors & added GC comment
Old 02-09-2009, 11:26 AM
mitchntx's Avatar
8", 10" or 12" springs will work on a 4th gen application. The longer the spring, the more suspension travel you will have before coil bind. Could be an issue with an 8" 450lb spring.
Quick Reply: DIY front coilovers
