Well those QA1 Coilovers definietely dropped my car....
Before:
After:
I replaced the front suspension with QA1 R series coilovers, 300lb springs and the rear suspension I did the heater hose mod with Comp Eng Drag shocks.
I am going to adjust the front up 1" - 1.5", this was a picture I snapped immediately after dropping the car after putting them in.
The rear is a good 1" lower than it was before, I had to stick 245/50 loaner wheels and tires on the car because I sold my Summit stars in favor of 15x10 Billet Street Lites with 28" MT Radials. I think the 28" Radial will help to take up the gap left in the rear.
After:
^^^removing the rear spring isolators and slipping heater hose onto the end of the top of the coil to seperate the coil frm the metal body and reduce noise
lowers the car a lil less than an inch
Thanks Ryan, so just bust out the spanner and start bringing up the front a little, would having the front lower like this hurt the launch performance/weight transfer? And is it better to raise the spring perches with the front loaded/unloaded/or doesnt matter?
Well i guess it depends on how you set them up. I assume you already know u can adjust the height. I just got some on my car. F-gen coilovers for the fronts with 275 spring and F-gen rear shocks too. So far, I like them. I got the single adjustables.
Hope that helps!
Ryan
You don't want it that low. Did you purchase a thrust bearing kit with it? If not you will be turning that adjuster for a long long time to get it up, you only get little bites at a time and will be there for hours. The easiest and best thing to do is remove the assemble from the car and screw it up 3/4 of the way up and reinstall it. If you need some help with this call in and speak with Jerry... he has a lot of experience with this set-up and the installation. If you remove and do not have the thrust bearing kit I highly recommend it, its $30 and makes adjusting so much easier.
Hope that helps!
Ryan
Hope that helps!
Ryan
