Removing the rear shock's
Old 03-04-2009, 04:50 PM
99SSragtop's Avatar
Default Removing the rear shock's
No big deal ?
Can you get at the top easily?
Old 03-04-2009, 04:51 PM
bobbyd's Avatar
rear shocks are easy to remove.
the nuts/bolts are on the top under the hatch carpet like right behind the rear seats.
its real easy to get to the top.
Old 03-04-2009, 06:24 PM
99SSragtop's Avatar
Im a convertible ???? LOL
I think mine are bolted in the wheel well some where.
Old 03-04-2009, 07:39 PM
m6ttop's Avatar
I think you have to remove a plastic cover
Old 03-04-2009, 08:34 PM
99SSragtop's Avatar
hmmm not sure
Old 03-07-2009, 07:15 AM
MUSTANGBRKR02's Avatar
so any vert guys have the answer?
Old 03-07-2009, 10:46 AM
99SSragtop's Avatar
pictures would help.
Im sure I can find it but right now where Im at I don't have my jack and all my tools.
Old 09-29-2010, 11:52 PM
tommyrussell's Avatar
I need to know same thing where in the hell is that top bolt I have a convert too.
Old 09-30-2010, 12:37 AM
libertyforall1776's Avatar
Me too -- haven't looked yet, but read you need to completely remove the seatbelt bracket to get any access to the nut...
Here's what someone else said on LS1.com:
The access for them are right behind where your back seat rests, so fold it down. Now that your seat is down look about 2 - 3 inches below where your seatbelt housings are. You will feel a soft spot in the carpet and there will be some perforated slits in the carpet. If you don't want to cut your carpet, take the whole seatbelt assembly apart from under the carpet and then fold your carpet forward. I opted not to do so because it wouldn't have gained me any room since my sub box is at precisely the same height and folding the carpet forward would infact lose me room unless I took out the subbox which was more work then I was ready for. So I cut the slits open, dug around in there moved the foam and started taking the nuts off.
Here's a write-up -- but not convertible specific:
http://www.ls1howto.com/index.php?article=8
Old 09-30-2010, 12:42 AM
sjsingle1's Avatar
think verts have the same cutout in the carpet as coupes.....just gotta find it
Old 09-30-2010, 10:57 AM
Xsta Z 28's Avatar
Thumbs up
Yes they do. . . . Super easy to get to!
Fold the back seat back down . . and basically near and below the two seat belt upper mounts you will find, a small 3 sided square of perforation marks in the carpet, with a very sharp knife cut the remainder open and make little "doors" in the carpet. There should be a wad of foam, remove it, and you will see the shock top.
Old 09-30-2010, 01:30 PM
TRANS-DAD's Avatar
Xsta Z is rite on the money!!........exactly how I did mine!!
Old 09-30-2010, 04:15 PM
rabbit320's Avatar
just be weary - if you release the top nuts of the shocks, the who rear end will fall, as the only thing connecting it to the body is the lca's and torque arm/drive shaft...
Old 09-30-2010, 07:55 PM
Sounds like deja vu.
Old 10-01-2010, 09:22 AM
Xsta Z 28's Avatar
Exclamation
Why yes it was . . . just confirming . . .
And pictures worth 1,000 words:
Old 10-01-2010, 02:45 PM
^ Nice, thanks for the pics!
One note on the above, the perforations are only horizontal -- just cut all the way behind the plastic -- remove the latches with the T-50 and you can get your box cutter or scissors back there.
Last edited by libertyforall1776; 10-30-2010 at 08:50 PM. Reason: added clarification
