Do you guys install the swaybars/LCAs/Panhard bar...
Old 03-07-2009, 09:04 PM
Trunion King
bene's Avatar
Default Do you guys install the swaybars/LCAs/Panhard bar...
w/ the weight loaded or not?
Old 03-08-2009, 09:35 AM
EchoMirage's Avatar
with weight. swaybars arent that vital with weight, unless youre tuning the car for competitive racing. but everything else needs weight to properly align, especially the LCA.
Old 03-08-2009, 09:40 AM
Moderator
davered00ss's Avatar
Loaded. Jack it up by the rear end & put jack stands there.
Old 03-08-2009, 02:03 PM
35th SS's Avatar
installed phb on both cars on a loaded position.just crawled under and changed them out.
Old 03-08-2009, 04:27 PM
UMI Performance's Avatar
Install the items with the weight off the vehicle. Finger tighten all the items and tighten the bolts with the suspension fully loaded.
Hope that helps!
Ryan
Old 03-08-2009, 04:28 PM
Nova5's Avatar
find the easiest loaded/unloaded point to remove the old bolts and install the new gear. Leave it a bit loose so when you let it back to the ground it seats into the loaded position. Tighten them up solid and enjoy your new found rear end stability.
Old 03-08-2009, 11:07 PM
Trunion King
bene's Avatar
Thanks for the replies fellas. I'll be tackling these mods tomorrow along w/ my Koni rears and Hose mod.
Quick Reply: Do you guys install the swaybars/LCAs/Panhard bar...
