Please help with QA1 install
I've got the UMI K member and lower a arms in. Now it's time for the QA1 coil over install. However, my stock set up is rusted beyond repair, so removing the nut on top is not happening.
So my question is, what parts will i need to order (I'll jus keep my stock spring/shock untouched incase the QA1 drag set up is too much)? Is it just the upper spring perch and shock mount?
Thank you
Thank you
