help installing lowering coils
Old Mar 17, 2009 | 08:04 PM
2002redhawk's Avatar
Default help installing lowering coils
I tried searching but i got alot of random posts.
I'm having troulbe installing my lowering coils. Im working on the front and have the shock bolts/nuts out. But i cant seem to get anywehre from there. Is there a good writeup / how to site for me?
Old Mar 17, 2009 | 09:52 PM
Giddswat's Avatar
This link should do the trick..If you have any problems let me know, I might be able to help you out some.
http://www.ls1howto.com/index.php?article=6
Old Mar 17, 2009 | 11:06 PM
Thanks! i got the front in. Hoping the rear will be an easy fix tommorrow.
Old Mar 17, 2009 | 11:23 PM
Magnet's Avatar
From what I have heard the front's are by far the hardest.. I'm going to be tackling this soon my self..
Old Mar 17, 2009 | 11:35 PM
The fronts are def. fun to work on. You do hafta unbolt alot of stuff. However the drivers side is harder then the passengers.
Old Mar 18, 2009 | 06:11 AM
Giddswat's Avatar
Thats good to hear! The rears are very easy to install, should take you around an hour or so. If you get a chance post a pic or two when you get it done.
Old Mar 18, 2009 | 07:48 AM
twitchtwice's Avatar
yea the front was definately harder. rear was easy.
Old Mar 18, 2009 | 02:34 PM
Ran into a snag. i noticed my front passenger coil wasnt positioned right on the pad. so i thought no biggie, unbolted everything. Got the assembly out. And wow. I cant undo the strut to get the spring out. I must of way overtightened it. I've sprayed pb blaster on it and it will not budge. Any tips?
Old Mar 18, 2009 | 02:55 PM
Greekey's Avatar
What are you using to remove it? A box wrench is a must.
Old Mar 18, 2009 | 08:43 PM
Got it all in guys. Thanks for the help. The rear i didnt even take the wheels off. Just jacked it up. Put on jackstands. lowered jack. and coils slid right out with ease. Anyways now my only problem is. My custom exhaust only hangs about a half inch off the ground. So im gonna hafta take it to a shop to get redone .
Old Mar 19, 2009 | 12:32 PM
and heres the problem...look how close the exhaust is to the ground!
Im going to try and see if an exhaust can fix the exhaust. Because i only have about .8 of an inch of clearance.
Old Mar 19, 2009 | 12:42 PM
Greekey's Avatar
Thats very low..Holy *****
Old Mar 19, 2009 | 12:52 PM
Yep. the right(passenger) side is fine. So im hoping they can fix the drivers side fairly easy. We'll see tho.
