Which Pan-Hard Bar to buy..
I have been looking into getting a Pan-Hard Bar for my car, which many people have told me on here that it would be a good addition to the suspension mods i have(Info found in SIG). I am also planning to get Weld-In Sub Frame Connectors?
But anyways what kind of BAr should I get?
Also any other good Suspension parts to get would be great to hear.
Hello,
Here are a few things to think of and decide if you need an adjustable panhard bar- If your vehicle is lowered or plan on lowering, if you are running a 315 or larger tire and if you are running a aftermarket torque arm or rear end.
If any of the above fit your application I highly recommend a adjustable panhard bar. We have adjustable panhard bars starting at $109 and a few different versions to choose from. Please see here for more information- http://www.umiperformance.com/produc...ategory_id=124
If you have any questions please ask and I will be glad to assist you.
Thank you!
Ryan
Thank you!
Ryan
I went with the "on-car" adjustable model............. http://www.umiperformance.com/2022?category_id=124
Thanks everyone for the recommendations!
The only difference is the more expensive item (#2022) can be adjusted while the panhard bar is on the car where as #2021 the single adjustable bar for $109 needs unbolted to be adjusted. Both items are built with the same quality and material... just the adjustment changes. Also all items are built 100% here in Pennsylvania USA
If you have any questions please ask. Thank you!
Ryan
Ryan
