Problems ASR Switch HELP!!!
I was driving home today and the ABS INOP light turned on as well as the ASR OFF light on the gauge cluster then I noticed that the little ornage light on the switch as well is off won't come on. What's going on? HELP!!!
The ABS and the ASR are both controlled by the ABS module. So if something goofy happened to the ABS module it will disable the ASR.
You'll need someone or something with the ability to read ABS codes to find out what went wrong.
