Have a bad shock, need new ones! SHOCK GURUS ENTER
Old 05-10-2009, 10:58 PM
JoshuaCole67's Avatar
Default Have a bad shock, need new ones! SHOCK GURUS ENTER
well i was putting my bmr lowering springs on and found out that one of my shocks it shot... i was wanting to get new shocks anyways so no time like the present... Right now i have the bmr 1.25'' lowering springs and some adjustable bmr lower control arms with relocation brackets if that means anything... I do alot (*cough*) street racing (*cough*)... What kind of shocks should i get... ay kind of info helps.. bad or good...
Old 05-11-2009, 07:55 AM
twitchtwice's Avatar
konis would be the number 1, then i would say bilsteins, then KYB
Old 05-11-2009, 09:39 AM
z28bryan's Avatar
I'd change that previous recommendation up slightly.
#1 Koni's hands down. Good compression setting, wide adjustable rebound range for too soft or too stiff. Great warranty, great build quality, etc... Ride quality can only be better than the next option given you adjust correctly.. if it's not then you adjusted the shock wrong
#2 KYB AGX's not the other crap. These aren't even close to Koni's because you'll probably never get the ideal compression and rebound setting with one **** that controls both. Worse build quality, KYB won't back up their warranty if you use lowering springs.
Bilstiens won't be valved to dampen aftermarket springs appropriately. I'd get the strano spec Bilstiens for a stock spring car that I just wanted a stock replacement shock for... note I'd get Konis for almost every application for this car.
Old 05-11-2009, 11:43 PM
ok.. where can i get Koni's???
Old 05-12-2009, 07:34 AM
stranoparts.com
Old 05-12-2009, 08:12 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
If you are doing a lot of drag racing then you might want to look at the Strange single or double adjustables.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 05-12-2009, 10:01 AM
ramairjohn2000's Avatar
i too might be in the market for new shocks but i do street driving with more autocross than drag racing. I currently have hotchkis lowering springs and bilsteins, and it rides and handles good?...i guess,suggestions please. thanks!
Old 05-12-2009, 11:50 AM
z28bryan's Avatar
Is that a question or an opinion?
Old 05-13-2009, 01:27 AM
ok.. well i do more street racing then anything but i rarely do that so it is mostly a DD with some racing on the side... What would yal recommend... i dont know alot about supsension but i know some from what i have learned on here
Quick Reply: Have a bad shock, need new ones! SHOCK GURUS ENTER
