Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Print Wikipost
Super Cheap Big Brake Kit - Info
Old 06-02-2009, 12:34 PM
  #81
Big_Bird_WS6's Avatar
^^^ idk. just a thought.
but what about the line?
Old 06-02-2009, 09:36 PM
  #82
Wesmanw02's Avatar
No Kore3 kit would correct the issue, its a matter of wheel offset unfortunately.
The lines need to be designed with the F-body fitting on the chassis side, and the Brembo fitting on the caliper side, and with the correct length. Which is why its best to order them from EB Miller at Flynbye Performance, you will get the exact lines that are needed.
Old 06-03-2009, 12:07 AM
  #83
some_punk's Avatar
Kinda hard to contact him. Is there any other sources for lines?
Old 06-03-2009, 01:19 PM
  #84
^^^ no ****. i might just make some of my own
Old 06-03-2009, 05:43 PM
  #85
Wesmanw02's Avatar
I just went on his website, went to the product, clicked add to cart, and payed him the $75 through paypal. And he sent me the lines.
Heres the link:
http://www.flynbye.com/catalog/i62.html
As for other sources for the lines, I don't know of any as of yet.
Old 06-11-2009, 07:23 PM
  #86
JasonWW's Avatar
Wesmanw02 has installed this setup and taken many pictures. He needed to space his rims out less than the 3/4" needed for an adapter, so he chose a spacer along with longer wheel studs. I'm going to link to his thread here as well as in the 1st post and I will include some of his photos.
Wesmanw02's CTS-V Brake Install w/ Pics
Old 06-12-2009, 11:34 PM
  #87
JasonWW's Avatar
R1 Concepts has a replacement 14" vette rotor for $355 a pair. They are pretty cool looking.
Old 06-14-2009, 11:03 PM
  #88
davidadavila's Avatar
loving this ****
Old 06-14-2009, 11:23 PM
  #89
what is the biggest rotor you can run without needing custom brakets?
Old 06-15-2009, 12:54 AM
  #90
JasonWW's Avatar
Originally Posted by davidadavila
what is the biggest rotor you can run without needing custom brackets?
Only the 14" Z06 rotor.
Old 06-15-2009, 02:28 AM
  #91
darknessxyz's Avatar
GOD DAMN ME. I just installed my C5 kit yesterday (Finally after 2 years) and cut the freaking ear off. Now you tell me the CTS-v caliper will bolt right in.
Good job on this JasonWW and all the contributed people. What's gonna be next JasonWW? Keep it coming.
Old 06-15-2009, 12:11 PM
  #92
if c6z06 brakes are same as Zr1 brake calipers (i mean the mounts are the same) then you probly could run a 15 or 15.5 rotor
Old 06-15-2009, 01:50 PM
  #93
ChaseSS's Avatar
will the core (center) of the ZO6 rotors rust or is there a coating on them to prevent it? I hate the look of rust on the centers and would probably end up painting them black if I have to?
And Jason, putting 1* negative camber on the wheel, is that something someone can do with their own tools or is that something a shop has to do? I love the way that looks, but I imagine you do go through front tires faster... not that its a big deal because mine isn't daily driven
thanks all for the info, this is a great thread
Old 06-15-2009, 03:10 PM
  #94
JasonWW's Avatar
Super cheap air ride?
Originally Posted by ChaseSS
Jason, putting 1* negative camber on the wheel, is that something someone can do with their own tools or is that something a shop has to do? I love the way that looks, but I imagine you do go through front tires faster... not that its a big deal because mine isn't daily driven.
Front end alignment should only be done on late model computerized alignment machines.
Adding some negative camber (0.5* to 1*) should help the tires wear more evenly (not wear faster). It did for me, at least. Assuming you like to go around corners fast, the factory spec of 0* camber tends to wear the outside edge. Plus you'll get more cornering grip.
I guess if you travel in a straight line mostly, then the inner edge will wear a tad more due to the extra weight on it, but wear should not be higher than normal.
Old 06-15-2009, 03:15 PM
  #95
Hugger Z's Avatar
All corvette calipers have the same bolt attachment points. So if you have the C5 or C6 conversion, you can bolt up C6 Z06 or C6 ZR1 calipers. Wheel clearance however, will be a problem for those monster calipers and rotors. 18" wheel needed for the 14" rotors and 19" wheel needed for the 15" rotors.
Old 06-15-2009, 03:35 PM
  #96
ChaseSS's Avatar
I followed your last write-up on that and you had me sold on it... Are you still planning on doing that? I'd love to see it
touche, I didn't really think it about it like that
Old 06-15-2009, 04:02 PM
  #97
Wesmanw02's Avatar
Why would you need the C5/C6 conversion to bolt up C6 Z06 calipers?? The Z06 calipers bolt directly to our stock LS1 spindles with no modifications needed.
And if you say that all the Corvette calipers attach the same way, then that means ZR1 calipers would be a direct bolt on to our spindles too. The mounting ears on the caliper are what determine rotor size, so theoretically the ZR1 caliper and rotor should be a direct bolt on, just like the Z06 setup.
Old 06-15-2009, 04:04 PM
  #98
Wesmanw02's Avatar
The GM Z06 rotors come with a coating from the factory to prevent rust. They basically paint the entire rotor (with a light/overcoat spray on the pad surface) and then let the brake pads clear off any excess paint.
Old 06-15-2009, 04:21 PM
  #99
so what is the awnswer can I get like 15 inch rotors.....and use still the ctsv calipers or the 6 piston corvette ones I'm confused
Old 06-15-2009, 05:04 PM
  #100
Wesmanw02's Avatar
Neither the CTS-V nor the C6 Z06 calipers will fit a 15" rotor. You would need the ZR1 calipers and 15.5" rotors for that setup.
Quick Reply: Super Cheap Big Brake Kit - Info
