C5 or C6 upgrade for LT1 brakes
I've been doing some searching and there is a ton of info out there but haven’t found the exact info I'm looking for. I'm about to purchase new wheels (C5 Deep dish 18X10.5 and 17X9.5) from OE wheels. I want to upgrade the front brakes for both cosmetic and function purposes.
My questions are:
-What is the difference between C5 and C6 brake setup?
-I'm looking at a set of Bob Bishop brackets, will they also work with the C6 setup?
-The C5 rotors are 13 inch correct? What size are the C6 rotors and will it fit behind a 17 inch wheel?
-If I do the C5 upgrade will there be any brake bias towards the front?
-Last, if I purchase the Bob Bishop brackets, used complete C5 calipers, and rotors/pads will I need anything else? Will my LT1 brake lines work?
Thanks for the help guys.
My questions are:
c5 and base c6 front brakes are nearly identical. c6 calipers are supposedly a better design than c5 calipers
Unsure. I used UMI brackets for my conversion.
c5 and base c6 rotors are the same. They fit many styles of 17" rims.
Yes, but that's a good thing.
You need conversion brackets (and need to cut your stock spindle), bolts for the brackets and for the abutment brackets (UMI sells the bolts as a kit for $20), base/z06 c5 or base c6 calipers and abutment brackets, pads/rotors, brake lines. LT1 lines are much too short. I used base c6 brake lines as they are 18". I would recommend base c6 calipers over the c5 calipers.
Pics:
https://ls1tech.com/forums/suspensio...installed.html
Pics:
Thanks for the info. Sounds like the C6 upgrade is what I will be looking for. Where is the best place to buy the C6 calipers? Just wait for some nice used ones? Don't the LS1 rears have a better E-brake? My LT1 rears and e-brake never seem to work correctly.
