LS1 Steering Column Into 96 LT1 Camaro?
Like the title says. I would like to put a 00-02 Camaro steering column into my brothers 96 Z28. Is this possible? If so whats involved?
I just finished installing a 2002 Camaro steering column into a 1994 Firebird. It is a direct bolt in. There is NOTHING different that I can see. All the plugs connected without any changes as far as I can tell. I haven't finished the VATS bypass but once that's done tomorrow I'll be taking it for a drive. The only thing that gave me a problem was that the shaft got pushed into the column and I thought they were different lengths. The shaft in the column is a two piece shaft and is collapsible thought I thought different lengths.
You will need both the column and the steering shaft from the LS1 car.
